Alright thanks Wes. Make sure to give me a couple of weeks notice. If it's not till fall, I'm cool with that. No rush. If I remember correctly I need the water pump, exhaust mani., down pipe and flex pipe for the BP. I'll look at our past PM's to be sure I'm not missing anything.
jcbgrady's BP swap
1993 Ford Festiva L ($650)
Mazda 1.8L BP - PaceSetter Header (in progress)
Aspire Swap - 15x6.5 wheels, 205/50/15 tires
>> Photo Album <<
I got to spend this morning in the garage and...
I ended up pulling the engine/trans with the axle still in it. I still have to separate them... somehow. Anyway, things are progressing again and I'm happy about that!
>> Photo Album <<
the key to pulling the axles is to use two prying bars at once. I'll place one long one, then just tie it off with a little bit of a load from a strap. Then I'll work the other one by hand, load it up, then just give it a sharp rap. See if you're just using one prying tool, yeah sometimes you'll just get lucky, but really you're actually just setting up a perfect "bind" situation. Use 2 tools at once, you'll be surprised at the result.
And yeah, the way I described is based on the idea that the engine is holding the trans, and the car is holding the engine lol.Last edited by iceracerdude; 06-06-2010, 11:34 PM.
Update. Finished up the asipre swap with some fresh hardware. New calipers, rotors, pads, bearings, drums, control arms and tie rod ends. Put new bellows on the rack and pinion, the old ones were almost non existent. And I mounted my 15x6.5 wheels running 205/50/15 tires.
Next month I get a bonus check that'll pay for my coilovers. Most likely it'll be these with 350f/250r rates. Any opinions?
Here are a couple of crummy pics.
>> Photo Album <<
those spring rates are probably a lil to stiff !
I have ground control coilovers with 250F 7 inch springs and 200R 7 ch springs id say there just a tad stiff by just a little only because cant get a shock with enough damper it bounces on kyb's just a little bitLast edited by skimsucka; 03-28-2011, 07:16 PM.93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
RIP_90 LuX http://www.fordfestiva.com/forums/sh...ad.php?t=32249
RIP 88 LX / B8-MEhttp://www.fordfestiva.com/forums/sh...ad.php?t=26398
RJ
Thanks, I'm building it for cone dodging, light track use and occasional fair-weather driving. So I'm looking for a stiff setup. I also have a lifted Jeep XJ so I'm used to a less then comfortable ride lol.
>> Photo Album <<
gotta love the XJ's gotta a pic of it?Originally posted by jcbgrady View PostThanks, I'm building it for cone dodging, light track use and occasional fair-weather driving. So I'm looking for a stiff setup. I also have a lifted Jeep XJ so I'm used to a less then comfortable ride lol.93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
RJ
2001 Jeep XJ, 4.5" lift w/ 33" MT's
>> Photo Album <<
Spent a the last couple nights working on the Festiva. Test fitting the engine and stock Festiva transmission for the motor mounts.
Terrible phone pics, sorry.
>> Photo Album <<
Doing a beautiful job, keep it up!!!1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
It's been a while since my last update. I've dented the firewall to fit the BP. Lined the interior, wheel wells, and rocker panels with truck bed liner. I put new rubber under coating in the wheel wells. Cleaned the engine bay and painted with black high-temp engine paint. Cleaned up the transmission, brake booster and master cylinder.
Then SC72 came up for a visit and helped me install everything except the battery for a final test fitting. Everything looks great! I have some questions about where some of the vac lines go and the wiring still to figure out. But I'm happy with what I've got so far!
>> Photo Album <<
Hey had a great time visiting with jcbgrady and his family, his two sons are a blast to be around, your car is comming along real well, keep up the good work, you will be driving it soon.Originally posted by jcbgrady View PostIt's been a while since my last update. I've dented the firewall to fit the BP. Lined the interior, wheel wells, and rocker panels with truck bed liner. I put new rubber under coating in the wheel wells. Cleaned the engine bay and painted with black high-temp engine paint. Cleaned up the transmission, brake booster and master cylinder.
Yeah, thanks for coming up Karl. Once this thing is running I'm coming down to visit you next time.
On another note - I installed a spare seat I had and while sitting in the car I was fidgeting with things and noticed the transmission wouldn't go in to any gear. Are there any common problems that might cause this? It's bolted to the BP and installed in the car. The clutch cable and pedal are installed and appear to work fine. The shifter is also installed but when the clutch pedal is engaged I cannot get it to go in to any gear.
Ideas?
>> Photo Album <<
I'm slowly getting the wiring done and I really wish I had another festiva for reference. I'm trying to figure out which wire goes to the black thing under the air intake? None of the festiva plugs seems to match it?
Also where does this ground go? Engine block?
And what are these?
Thanks for any input.
>> Photo Album <<
