my girlfriend has been working on the cluster shes got big plans going down, uv lights in the dash and shes painting the numbers and such to glow with the lights
Claude's BP SWAP..... :)
looking good, i like the grill
Mike, AKA the sasquatch
also to answer perucho, vacuum gauges actually can be quite handy you just have to know how to read them and what the readings mean, they can tell a lot about an engine/ compression/many diagnoses on issues. so I plan on using it on my bp which also will have a free vacuum port on the manifold so instead of capping it ill be using it, the gauge will be able to tell me if I have bad compression, or good, if my lifters are sticking, if my rings are worn/bad, if my timing is late, also valve timing ,poorly seated valves, blown head gasket, if i have exhaust issues (clogging), and a whole lot more all just by monitoring where that needle moves and how it moves, so its not just something I got to fill in the spot...I want to be able to monitor my bp as closely and accurately as I can and with the vacuum gauge and a little background on how to read and decipher what I'm reading it will really save me if/when I run into issues.
	Second Chance Garage — neon‑pink slots, rapid payouts, and nightly tournaments. Join now and claim your welcome spins.
Take a look at this if your interested at all it explains a little more about how vacuum gauges are used
also in order to utilize all these functions you need to have a non digital needle gauge so you can see how the needle moves, In searching I came across some digital vacuum gauges and those really just defeat the purpose of having one, all they can tell you is a number reading which really does nothing for diagnosing issues. so make sure you get a non-digital one if anyone is interestedLast edited by Claude; 08-04-2010, 08:56 AM.
Nice. Big difference in ride?93L sold. First FESTY!
91L blue monster "BP swapped!" Robbed of its Heart for other Festy!
91GL blue bandit(thanks to sparky) Sold twice! lol
89L (thanks again to sparky) "SCRAPPED without my permission!!!!:nono:
93L Clean Green Machine! (Thanks to Sedat)-Sold to other member!
89 Auto LX Wrecked and stripped. violin
93GL Sold Too Soon!
91GL BP powered, ALL OPTIONS! banana time
Looking good claude! You are really doing a nice job/ paying attention to detail...i have a quick question, I got the same gasket/seal set that you did for my b8, and there are some seals in it that I do not recognize... its a small metal tube, with a rubber grommet around it, theres 6 of them. Theres also 6 o-rings, and I dont know what they go to. Thanks and keep up the good work!Tyler
91 Festiva, 5spd, B8 swapped, now for paint and suspension
 did the same with the gauge pod, some bondo and several nights of shaping/working and the pod really came out looking stock. im pleased with it.
