Claude's BP SWAP..... :)
  • my girlfriend has been working on the cluster shes got big plans going down, uv lights in the dash and shes painting the numbers and such to glow with the lights
    91 red l-
    • What is the vacuum gauge for?
      Oscar
      • where do you find the mesh for the grille??
        • ebay but i think theres pretty similir stuff at home depot
          91 red l-
          • looking good, i like the grill
            Mike, AKA the sasquatch
            • Thanks! amazing what a little bondo can do did the same with the gauge pod, some bondo and several nights of shaping/working and the pod really came out looking stock. im pleased with it.
              91 red l-
              • also to answer perucho, vacuum gauges actually can be quite handy you just have to know how to read them and what the readings mean, they can tell a lot about an engine/ compression/many diagnoses on issues. so I plan on using it on my bp which also will have a free vacuum port on the manifold so instead of capping it ill be using it, the gauge will be able to tell me if I have bad compression, or good, if my lifters are sticking, if my rings are worn/bad, if my timing is late, also valve timing ,poorly seated valves, blown head gasket, if i have exhaust issues (clogging), and a whole lot more all just by monitoring where that needle moves and how it moves, so its not just something I got to fill in the spot...I want to be able to monitor my bp as closely and accurately as I can and with the vacuum gauge and a little background on how to read and decipher what I'm reading it will really save me if/when I run into issues.
                Take a look at this if your interested at all it explains a little more about how vacuum gauges are used
                also in order to utilize all these functions you need to have a non digital needle gauge so you can see how the needle moves, In searching I came across some digital vacuum gauges and those really just defeat the purpose of having one, all they can tell you is a number reading which really does nothing for diagnosing issues. so make sure you get a non-digital one if anyone is interested
                91 red l-
                • kyb gr2
                  got started on putting my remaining ggr2s on the front end,
                  91 red l-
                  • Nice. Big difference in ride?
                    93L sold. First FESTY!
                    93GL Sold Too Soon!
                    • definitly. im sure it will be much better when i replace the tophats and springs as well, just gotta do one thing at a time.
                      91 red l-
                      • wow I wish my wife would help like that!!!
                        • Looking good claude! You are really doing a nice job/ paying attention to detail...i have a quick question, I got the same gasket/seal set that you did for my b8, and there are some seals in it that I do not recognize... its a small metal tube, with a rubber grommet around it, theres 6 of them. Theres also 6 o-rings, and I dont know what they go to. Thanks and keep up the good work!
                          Tyler
                          91 Festiva, 5spd, B8 swapped, now for paint and suspension
                          • i dont know that we got the same thing, i dont recall anything like that sorry, cant remember everything that was in it
                            91 red l-
                            • alright lol ill ask around....i thought maybe they were injector seals but they dont quite fit. Thanks,
                              Tyler
                              • maybe if u take a pic i or someone could ID them
                                91 red l-
