Eurotiva BP/RT build
  • Are you running slicks Greg?
    Can't wait to see the new times! :thumbup:
    WWZD
    Zulu Ministries
    • 11.90s here we come:wav:
      Never Hire a Boy to do a Man's Job!!
      • Do You still have the Capri rims with the crazy paint?
        That boost gauge isn't going to work for you.. only goes to 20psi lol
        -M3NTAL MARK! Woo!!
        • I'm amazed...I'm sitting here in class reading this...I'm just amazed! Is it at all possible to run a BPRT on a 97 Aspire?
          • Originally posted by Zanzer View Post
            Yeah same old slicks
            fingers crossed.
            Yeah they are just sitting here rotting away. Yeah it's cool to watch the boost gauge go past the numbers. My gauge on the drivers side only goes to 20 too.
            -Greg
            Redneck Engineer
            FOTY - '09
            • With all that rust you found you should be light enough for 11's
              91GL BP/F3A with boost
              • ^good point.
                had a old DVD sitting not being used, so I put in the the Festiva. why? Because it's a streetcar.
                And I traded for a catch can a while back, so I figured it would be a good time to install it.
                -Greg
                Redneck Engineer
                FOTY - '09
                • More engine bay pictures . Kinda like upskirt shots haha
                  New build on the way .
                  • ^ rofl
                    -90 festiva - bp swap "relentless" (thanks matt) aspire swap, pacesetter, underdrive pulley
                    -90 festiva - surf blue (undetermined destiny) wanna keep but wifey says noooooooo
                    • Why are needing catch can? Is problem with motor?
                      • Had it, figured why not put it on? For some reason at 20 lbs of boost oil is starting to come from multiple spots....lol... This motor is hurt, but will be going to the track before any further inspection.
                        It has bubbles, that smell like exhaust. And it's pressurized within seconds of starting a cold engine. Hg....
                        -Greg
                        Redneck Engineer
                        FOTY - '09
                        • Catch cans are very common with tarbo setups. Or anything with PCV really. Why have that oil going into your intake when it can be caught in a container to be drained later?
                          • My PCV vented to the atmosphere
                            • Tighten the head bolts (I don't think you have studs) and I know your not scared to run it.
                              I'm really shocked that you have never bought a M factory Diff with all the racing you do.
                              -M3NTAL MARK! Woo!!
                              • Stock diff... because streetcar :p
