If you're getting a puddle below the MC on the ground, then there's got to be a leak. (He said, stating the obvious
) Double check where the MC mates with the booster, and where the reservoir plugs down into the MC. They are kind of notorious for leaking there. Also wouldn't hurt to closely inspect the gang valve where the lines from the MC connect with the hard brake lines going to the wheels. Just a couple of thoughts.
Looks like your project is off to a good start. Always a good feeling when it moves under its own power for the first time.
) Double check where the MC mates with the booster, and where the reservoir plugs down into the MC. They are kind of notorious for leaking there. Also wouldn't hurt to closely inspect the gang valve where the lines from the MC connect with the hard brake lines going to the wheels. Just a couple of thoughts.Looks like your project is off to a good start. Always a good feeling when it moves under its own power for the first time.
Because I got it in great mechanical condition now.
