Your most likely not familiar with the f's but would you happen to know where it sits compared to the G?
1991 turquoise festiva progression thread
I'm thinking my G series 4speed auto will push the engine forward a good bit as well (hoping anyway). Maybe I can get away with not shifting the whole mess toward the Pass side which I should be able to do since the trans isn't wider side to side just front to back. If so then I'll probably BP it later on. Doing it with a B3 first just to see how much gas mileage I can squeeze from it. Looking forward to seeing how the rest of this build goes
Going good so far!
No festiva for me ATM...
The F and G series tranny's locate the engine roughly in the same position, I used to have a BP/F series swapped festiva with no firewall modsOriginally posted by 91mcnasty View PostYour most likely not familiar with the f's but would you happen to know where it sits compared to the G?
Be better than the 3 speed anyway lol89 L, hopefully returning from the dead soon with a little more power... :twisted:
http://www.fordfestiva.com/forums/sh...77-my-89-build
^ Way better! With lockup torque converter it should be turning only ~100-200RPMs higher than a 5 speed manual on the highway. As opposed to the several hundred more that the 3 speeds do
I'm not a big fan either, but wifey is lol, she refuses to drive stick even though I've taught her and she can she just won't lol.Originally posted by 91blufestiva View PostThanks htchbck! I wouldn't mind seeing that 4spd auto done either! I'm not a big fan of auto's, but it should still be interesting to see at least!Last edited by htchbck; 01-10-2012, 02:14 PM.No festiva for me ATM...
Awesome! So I cut up my firewall for nothing!!!!
Blue festiva, did you get the G from the junkyard? Jw1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
^ No I had a complete running Capri Xr2 with the b6t, I parted it out, was gonna try rebuiling the b6t and swapping that in, but then I didn't have money to finish the rebuild and now it's still sitting in pieces.. Now I decided I wanted to go BP, so I figured I'd use the G-series so I don't have to mess with babying the E-series.-Josh R
Sounds like a plan!1992 white L, Bp, American racing 13's, stock trans.
