thx all, so the car is running and drivein
project festy dd!
oops pressed enter by accident hahaha
so the car is running and driving now pics will be up tomo, took a whole day to sort out little issues here and there but i stil have one issue........
: im running b6k1 ecu and green top injectors
i had an 88 mazda 323 maf that i plugged in and the car started but felt super super super super slow in the high rpms, i couldnt figure out what it was. just out of curiosity i plugged in the normal festiva maf and it felt like the car gained about 90 hp LOL, it feels super supe rfast now BUTT.... the idle is stupid high and i cant fix it with the idle screw its that bad.
first question: what maf number/code do you b6 swapped guys run?
second question: What temperature of plug is good for a turbo car? im buying new plugs tomo im thinking cold plugs are better for turbo cars but im not 100% sure which ones to buy?
third question: what should my timing be at? right now i think its around 8 degrees if my princess auto timing light holds true.
thanks thanks!!!!
the ones i had on my boosted miata were for a boosted miata and they were baller expensive but i never remember what they were
will any old 323 maf work? or is there a certian code because the 323 maf i have makes the car feel like it has 10 hp
and the festiva maf makes it feel like it has 20, but idles at like 1500 rpm
ok now im having difficulties that are getting me right angry
my idle is super super high. Someone on another thread told me to clean the iac but im thinking i have the wrong one .
i have the b6k1 ecu with b6s7 maf box and green top 323 injectors
BUT..... i have an intake manifold off a 1987 mazda 323 and the IAC looks completley then festiva.
can anyone give me some direction? can i use a b3 iac even though it doenst bolt up to the older intake mani or is my problem completley different
and no its not timing.
thanks.
