Just read entire thread. A pleasure to read nice work!!
Kenny's B6t Festiva
Depends on the piston. Wiseco/JE/Probe/Arias will make you anything. They have the piston design already in a CAD file. All they do is re-compute depth of the crown and upper ring land and they can CNC any compression ratio you want (within reason).Originally posted by rbrown View PostCool. I understand those Wisecos raise the compression just a tad and Iwas was going to do some minor head cleanup.1989 Carby L: Stock. Slow.
1998 Mustang Cobra: ported heads, cams, longtubes, 4.30 gears
2016 Focus ST: daily driven go-kart
I think the 7.9 is much too low on these motors.Originally posted by DON SVO View PostDepends on the piston. Wiseco/JE/Probe/Arias will make you anything. They have the piston design already in a CAD file. All they do is re-compute depth of the crown and upper ring land and they can CNC any compression ratio you want (within reason).
I guess I migt drop them a line and see what they can do.Rodney
1991 FI 5 Speed Aqua Blue
7.9cr is useable for race only and at 25+ psi of boost, and even then, it's not a fun engine. i'd stick with a 9:1 minimum to keep throtle response and off boost power. it makes the engine much easier to live with.Trees aren't kind to me...
Originally posted by ELUSIVE View PostJust read entire thread. A pleasure to read nice work!!Thanks for the props man!!!!Originally posted by rbrown View PostCool. I understand those Wisecos raise the compression just a tad and Iwas was going to do some minor head cleanup.
and yes my wiseco pistons do raise my CR i believe its 9.1 now, and i agree 7.9.1 is way too low,
RESURRECTION!!!! of a dead thread
i been secretly working on my festiva the last couple weeks, i shaved my door handle on the driver side, also fixed all the dents and primed my door and fender, no longer blue.
042 by snestiva, on Flickr
041 by snestiva, on Flickr
I Rolled Bedliner on the interior of the Festiva, i like the look and it works as a sound deadner too, here are before and after pics
039 by snestiva, on Flickr
040 by snestiva, on Flickr
044 by snestiva, on Flickr
048 by snestiva, on Flickr
Just finished installing a gtx digital Cluster everything works and a trimmed the dash to fit, i think im gonna go buy a couple more trim pieces and see if i can cut them a little better
084 by snestiva, on Flickr
085 by snestiva, on Flickr
Looking great man. I love the Festiva in Yellow!
Edit: Bummer, I just browsed through the thread and it looks like you are gonna eventually paint it black with the grill and gas cap already done. That will be cool too, but I was looking forward to a Yellow Festy!
its Staying Yellow nowOriginally posted by Prafeston View PostLooking great man. I love the Festiva in Yellow!
HOORAY!!! Good to hear!
Yeah, that digital cluster looks pretty awesome. Does it only work with the harness for that engine?
OMG! I need that cluster! Where and how much can I get one for?
1990 Festiva L White: R.I.P.
1988 Festiva L Silver: R.I.P.
1989 Festiva L White: R.I.P.
no it works with the stock festiva harness, all i did was get the pinouts for both clusters, i popped all the pins out of the festiva plugs and put them in the corresponding spot on the mazda plugs, looks factoryOriginally posted by Prafeston View PostYeah, that digital cluster looks pretty awesome. Does it only work with the harness for that engine?
good luck finding one they only came in the 1988 and 1989 323 gtx, and not all of them had digital clusters,Originally posted by TheresGabe View PostOMG! I need that cluster! Where and how much can I get one for?
I have an analog GTX cluster in my festiva andi once tried swapping it for a digital one, the digital one is surprisingly bigger and was a PITA to install, only to find out the tach didn;t work
so the analog went back in haha
Nice to see you still working on it
