^^yup lol I actually gave Paul the spliced harness I used when I was running the B6T and the original harness to the GTX stayed in the GTX lol
My 88' GTX project
This topic is closed.
Got some work done on the GTX tonight, i started by bolting the B6T and trans together, i realized my B6T came from a FWD GT because i had to cut a piece of the oil pan off to clear the AWD trans
Here's where i had to cut clearances
And on a side note, even with the engine/trans out of the car, what a PITA the starter is to install!! lol
I beleive i am also missing the bracket that bolts to the body for where the engine mount bolts to, so i'll need to search for one of those as well
Then i wen to bolt the crossmember back onto the car to install the engine and i had troubles installing the rear bolts, so i'll need to get a tap to clean the threads on the body before i can finish bolting up the cross member, but i did also get the stabalizer bar bolted back in
Then i emptied most of the parts out of the GTX so i can start sorting through everything so i can start making sense of all the parts i have and may need
Then some interior shots..... and yes the interior needs a good cleaning
and then i got the fenders bolted back on, mainly so there not in my way :lol:
Looks like its coming along well!
I just picked up my BP for the Pro Yesterday, need a BP clutch kit so I can bolt the engine up to the trans.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
here's tonights progress
This tranny is very wide (front to back wise) it was definately meant to be installed from underneath, if the master cylinder was installed, it would have been in the way for sure
But after a lot of fighting with it, here it is
next came the hood and headlights etc
^^Oh no :lol: i want to see how fun this thing will be in the snow :evil4:
Ugh, want digital cluster so bad.Current cars:
looking good
im also working on my 323 gt so i can drive that around... cant wait to drive with boost again
Mike, AKA the sasquatch
Last night I got the front axles in, the clutch and brake master cylinder installed, the rad is installed and the slave cylinder, next I'll be getting the wiring taken care of and getting the gas tank ready to be re-installed so I can get the long drive shaft mounted
The engine bay is get more full.......... Most of the wiring is connected, and once i get the gas tank cleaned out and re-installed i should soon be able to fire it up
lol well i gotta get this thing finished so i can get my festiva back in the garage :lol: so i got motivation, plus i really want to test the AWD in the snow :evil4::evil4:
Thank you Paul, but a big thanks to you for hanging onto it for me til i was able to come get it
