This is the start of a likely very long build thread. I have been buying parts cars, stripping them of what I need and storing everything for a B6T/G25MR/Aspire swap.
I will be adding prices to everything I've bought just so I can have reference. (Nothing is for sale)
This is what I started with over a year ago for $500 Ended up having a burnt #2 intake valve.
Bought this to fix, ended up as a parts car unfortunately. Can't find a better picture either. It was a 92GL that had overheated.
Also bought a 1997 Aspire with 130,000 miles that needed a transmission.
Used the motor and swap stuff on blue car.
So far I have done/added the following:
Swoopy Power mirrors. $36
Spray painted blue (bad idea). $100 +
New inner and outer tie rods, control arms, and rack boots. $100
VC Gasket. $18
Plugs/Wires. $20
Distributor cap and rotor. $25
Ebay cone filter/adapter. $20
Fuel filter. $20
Tach cluster. $25
Intermittant wiper switch (install pending). Free From OSX
LX console with shift boot. From parts car
Hatch light with door switch latch (install pending). From tderronne ($80 total)
Spoiler (install pending). From tderronne ($80 total)
Hatch cover. From parts car
New brake pads. $20
Replaced driver side knuckle for one with good wheel bearing. From parts car
Complete blue stripe interior with super nice plastic. From parts car
New auto seat belts (install pending). From parts car
Aspire Swap-New rotors, calipers, bearings all around, brake pads, drums, shoes, wheel cylinders, and rear brake lines. $220 From $275 Aspire parts car
VX Wheels (has 175/70-13 right now, want 185/60-13). $200
How it looks now...
Bought the Aqua 92L thinking it would be my swap car but decided that since it has AC that I don't want to mess with I would just swap my blue car. Got it for $250 because it needed a transmission. Oddly enough I had one lying around.
Found a 91 XR2 on Craigslist, 68,000 miles but it was super rusty for some reason. I drove it and it ran great like it should. Clutch was even good enough to break loose wheels in second gear. Guy initially wanted $1200. After a month without any bites he lowered it to $900. I got it for $700, got what I need, and sold it (and a brand new soft top) to Capri Type-R (Russ) for $350 plus a Rocketchip ECU.
Ripping it out...Safely.
More to come...
Comments and suggestions are welcome.
VC Gasket. $18
Plugs/Wires. $20
Fuel filter. $20
Tach cluster. $25
New brake pads. $20
How it looks now...
More to come...
Your's will look awesome lowered!
