Originally posted by Safety Guy
xaero_81's B6T/G25MR Build Thread
Yep, Krylon "True Blue". Maybe someday I'll tear it down and do a real job, but for now maybe a good buffing will do the trick. The only thing I have wet sanded and cleared are the front fenders.
I love that color!
Went to install my variable intermittent wiper switch today. Kept on blowing the fuse.
Did a search and found this:
I too won my switch from OSX and it must be the wrong one.
Guess I'm off to see if I can find me another.
by any chance was that wiper switch from a mpv?
Mike, AKA the sasquatch
ya thats the mpv one.... it fits, plugs in and looks like it will work but the wiring is wrong, it will blow the fuse every time... had to learn that the hard way
you can use the mpv arm but you have to use a diffrent delay box (the smaller one found in the festy, 323 and 626...)
Lookin good! Was cool getting to meet you over the summer. I envy that shop you have to work in there...1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
Thanks! Looking forward to one of those Capri meets that Brad went to earlier this year. I have Capri fever right now and am sort of looking to buy one, so keep your eyes peeled for me. Will likely want another Rocketchip if I find a daily XR2. Yeah the shop's great, until last year though I had to rough it in the driveway. I know your pain.Originally posted by Rocketman View PostLookin good! Was cool getting to meet you over the summer. I envy that shop you have to work in there...
Getting ready to spend some tax money for a full gasket kit.
Thinking of this one:
Also still debating on whether or not to get Raceland Coilovers. These:
Also want one of these. Not sure about the 2.5" though.
And maybe this, although my stock clutch is fine.
Mainly looking for opinions on the Rock Products gasket set but thoughts on anything else is appreciated. Will be doing a timing belt kit and water pump as well.
Edit: Oh, and I'm somewhat thinking of the Mfactory LSD if I can find one for less than retail ($669). Trying to prevent the Achilles heel of the standard engine swapped Festiva.
Thanks,
DonnyLast edited by xaero_81; 02-23-2011, 03:21 PM.
i want an Mfactory diff as well although i've never seen any used ones for sale
Eventually if i get more horsepower then my tranny can handle, i may look into a better tranny, not a mazda one though
Actually after having driven my Yaris for a couple of months I decided your clutch isn't too stiff at all. My only prior comparison was my worn Festiva one.Originally posted by bhazard View PostThat's basically the same clutch I have and you hate it.
I've been looking around to no avail so I may just have to bite the bullet. I've seen them as little as $650 shipped new whereas Mfactory direct sells them for $669 plus shipping I think.Originally posted by Damkid View Posti want an Mfactory diff as well although i've never seen any used ones for sale
I don't plan on having V6+T numbers so I doubt I will venture outside a G-series. Even with the LSD I would assume I would break tires before my transmission.
Oh you don't need a V6+T to break G series tranny's lolOriginally posted by xaero_81 View Post.I don't plan on having V6+T numbers so I doubt I will venture outside a G-series. Even with the LSD I would assume I would break tires before my transmission.
Car's looking great !!! Keep us update.
Maxim
