Wow that looks really good!
minigun gauges...
Looks very good!!
I still have to change the steering wheel ( open for suggestions) paint the colum and install the turn signal/ high beam lightsmoney pit
No spitters were I work, you swallow it all. The Company feels if you already have it in your mouth why waste it.
Remember you need a hub , search ebay for 87 RX7 hubs. Theres 5 and 6 bolts hubs , the 6 one is the common ones for the cheep steerings.Originally posted by NovaSS View PostI still have to change the steering wheel ( open for suggestions) paint the colum and install the turn signal/ high beam lights
At first I wanted this :
But im going with this I think , but I donno if its gonna fit well since its a deep dish one model (maybe too to the front with the hub and all).
installed the turn signle and high beam lights across top, the bottom left one is running lights and right one is nitrous armed
money pit
no problemo , I really like the blinkers , where did you find those? On the taurus I used just regular tiny leds , but I really like yours.Originally posted by NovaSS View PostThanks again for the lead on the gauges !
Oh and a little tip , plug everything into a connector male/female (i used a old sho connector with 8 wires passing through it). It makes it alot easier to pull everything when you want to service it. Unscrew - unplug and the dash is on the bench. I made that mistake at first with the taurus ( When you want to get it out , you cant....)Last edited by PhoenixSHO; 02-19-2011, 01:28 PM.
Looking real good!
Are you going for an aftermarket or different steering wheel?
