NICE!!!!!! ive gotta get the speedo and tach!! tired of only being able to see 85 mph!
minigun gauges...
88 festiva lx, 2.3 turbo rwd swap in progress
1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
03' gt, full termi swap 700+ whp build
sponsered by,
pam pam's junk, dayton OR.
Bob's ok tires, salem OR.
Clausen Truckin', keizer OR.
6 gauge set runs $468 but thats with all sending units and wiring. I up graded to a GPS speedo and that tacked on an extra $100. To have MINIGUN added to the faces was only $10
so much for my tax refund.money pit
No spitters were I work, you swallow it all. The Company feels if you already have it in your mouth why waste it.
thats pretty reasonable on price, cheaper than most highend gauges.
sponsered by,
yep when you consider they included all the senders and wiringOriginally posted by 1988festivazoom View Postthats pretty reasonable on price, cheaper than most highend gauges.money pit
Dam, I should order some gauges through them
Thanks for pointing me to them, Im very happy with them.Originally posted by PhoenixSHO View PostVery nice , I should get mine this week , I ordered them last week
money pit
Beautiful! You could buy another Festy for that price !! lol1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
1969 Ford F100 Big Block Ranger and it was free! (coming 2/12)
After moving them around this is how they are going to look. Above the middle oil pressure gauge willl be the turn single and high beam indication lights. The board will be covered with carbon fiber
Hmmm... I guess you don't really need a gas gauge since you will always know your almost out of gas :lol: But what about temp? With the long piping under the car (like my wife's Fiero) and the general nature of a rear engine cooling system I think I'd want to know exactly whats going on in there at all times. Are you planning on using a separate gauge pod for the others or mounting them elsewhere in the dash? Looks good though, I once built a gauge cluster out of plywood
Except I used the plywood in place of the PCB! Lol
I'd like to do something similar on the next festie I get, but hopefully I can find some slightly (maybe 1/2"-3/4") smaller gauge faces so I can have it setup like my Miata. Never seen a gauge cluster that quite compares to the simply elegant while completely utilitarian first gen Miata gauges. Tells you everything you need to know at a glance (assuming it is one of the years that uses an actual sender rather than a switch for the oil pressure gauge)
No festiva for me ATM...
The gas , water temp and volts will be mounted in the shifter console along with a check engine light. They make a smaller tac and speedo, 2 5/8 I think but I just needed the 3 basic to be in line of sight at all times.Originally posted by htchbck View PostHmmm... I guess you don't really need a gas gauge since you will always know your almost out of gas :lol: But what about temp? With the long piping under the car (like my wife's Fiero) and the general nature of a rear engine cooling system I think I'd want to know exactly whats going on in there at all times. Are you planning on using a separate gauge pod for the others or mounting them elsewhere in the dash? Looks good though, I once built a gauge cluster out of plywood
Looks like you would probably have room for a CEL up there too, and maybe a temp light what would come on if the temp got a few degrees over the high side of the normal range. Dunno, I guess I've just had too many cooling system problems over the years to drive something without a temp gauge right in front of my face lol.No festiva for me ATM...
I like that set up. As shown with the Miata gauges the oil press is right in the middle.Originally posted by NovaSS View PostAfter moving them around this is how they are going to look. Above the middle oil pressure gauge willl be the turn single and high beam indication lights. The board will be covered with carbon fiber
Having a oil press gauge in your face has saved my dads bacon at least one time.
After rebuilding his 5.0 and firing it up for the first time we were doing some fine tuning with timing and such. He was sitting in the drivers seat when the gauge dropped. He was able to shut it off right away. Turned out the machine shop didnt put one of the oil galley plugs back in right and it blew out UNDER the timing cover. So no visable leak and no pressure. That and the plug blew into the timing chain taking that out with it.
Oil pressure and tac are my priority, with the speedo to round it off.
I would have liked the temp in there too but there just isnt enough room with out making it looked cramed.money pit
