Got everything hooked up and ready to give ignition last night, hooked up the battery and the main fuseable link started to smoke and make a arc-ing sound if alternator is hooked up soo... tonight, going to plug it in and pull out fuses until we find which system is causing it and hopefully we missed a ground that wont be too hard to find. Wish me luck!
"Nastiva" b6t build thread
I dont think it will be too bad, I see it as a good thing cuz i now i know where all the wires go, so i plan to do a moderate wire tuck while the motor is out and also clean some things up a bit
-93' Festiva L (B6T swap in progress)
-92' XR2 Capri (Parts car)
pulled the motor and replaced the rear main seal and oil pan gasket tonight mostly everything went smooth until we went to put in passenger side axle and i pushed so hard i got a hemeroid (talk about sacrafice haha).. still didnt go in
any suggestions to get it in easier?
lube :pOriginally posted by festivBS View Postany suggestions to get it in easier?
Mike, AKA the sasquatch
Project has been sitting for a while but since my last update i have gotten a new walboro 255 (old ebay one went out on me) purchased a rocketchipped ecu (waiting on delivery) finished the exhaust, installed gauges (AEM- tru boost, oil pressure, wideband and an autometer pro-comp memory tach) converted rear from lug bolts to actual studs with lug nuts, and made a short throw shifter (using sasquatch's idea)-93' Festiva L (B6T swap in progress)
Loookin good !!93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
RIP_90 LuX http://www.fordfestiva.com/forums/sh...ad.php?t=32249
RIP 88 LX / B8-MEhttp://www.fordfestiva.com/forums/sh...ad.php?t=26398
RJ
