If it would just sit like this it would just barely clear but it literally sits on the rail.
And yes I'm gonna need some touch up paint It's just collateral damage
So here's what I'm thinking...
On the front tranny mount im going to drill ou the existing 2 bolts that connect to the crossmember, weld a shim to the underside of the mount, which will in turn lift the front of the tranny and motor, and finally throw some new longer bolts through the modified mount.
Look back and you'll see i didn't need to make the rad support removable (it just made it a hell of a lot easier), remember, I got my mock up engine in without any cutting
A hunch is creativity trying to tell you something.
so if you don't mind me asking how much have you spent so far on this build, because thats the way to do a swap. Getting everything done before even dropping it in.
Total Investment in the car including paint, parts, buying a capri xr2, machine shop, accessories (hids) 20 cans of brake kleen lol about 3000 total.
pretty much built from ground up with almost everything new..shocks, sway bar, bushings, LCA, bearings, rotors, tie rod ends, head (valve job, resurfaced, seals) block cleaned, honed, crank mic'd polished, radiator, fan, IC, IC piping, rings, thrust washers, rod bearings, main bearings,gaskets, radiator hoses, heater hoses, coolant crossover tube, thermostat, paint for transmission, axle seals. Etc etc you get the idea lol
