Daniel's TruckStiva Build Thread (56k warning)
  • Originally posted by Nerd Racing View Post
    I have to get some coilovers for my setup, I'm trying to decide if I want to go with racelands or just get the civic cheapy ones and QA1's. i will not be slamming this thing to the ground so I doubt I'll need helper springs... What coilover system do you plan on using?
    mazda 626 rear struts with ebay coil over sleeves with summit racing springs for now and festiva kyb's on the front with the same coil over set up
    1991 stiva.
    • been busy with alot here recently military, hazmat, school and work so I havent really got a update other then i got some hubs, bearings and seals. I pulled the AWD trans from the back of the building today and took a few pics.
      1991 stiva.
      • Is that BG chassis trans? it looks a bit different then the GTX trans i had
        • ^^ yep its a GTX trans I believe (BG GTX that is)
          Facebook Me!
          • Originally posted by Damkid View Post
            its from a 88 323gtx BG bolted to a true bpt engine from japan. I dont know much about this trans other then it doesnt use the diff lock motor because it has a viscous differential stock. ...if anyone knows much about it entertain me thanks
            1991 stiva.
            • It is not from an 88/89 GTX (those are BF chassis) it's from a 91(?)+ JDM GTX. Never available in the states
              1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
              Rocketchips!
              Bolt-on Weber Carb Adapters!
              • Originally posted by Rocketman View Post
                when I bought the engine and trans it was listed for a 88-89 mazda 323 gtx.. I know this could be wrong... I just read a article on Google somewhere where it said the 88-up gtx from over sea was this transmission.. the only difference Ive seen so far between this and the gtr was the gtr had shoot peened first or second gears ..idk just what I read also its hard to believe much ,,, and I know you have been around a bit lol
                1991 stiva.
                • G5MX-R
                  Used with
                  B6-M
                  BP-ME
                  BP-ZET (GT-X)
                  ID Code
                  G5F0
                  G5F3
                  G5F1, G5F5
                  Type
                  5MT, 4WD
                  5MT, 4WD
                  5MT, 4WD
                  1st gear
                  3.307:1
                  3.307:1
                  3.454:1
                  2nd gear
                  1.833:1
                  1.833:1
                  1.833:1
                  3rd gear
                  1.233:1
                  1.233:1
                  1.310:1
                  4th gear
                  0.914:1
                  0.914:1
                  0.970:1
                  5th gear
                  0.755:1
                  0.717:1
                  0.717:1
                  Front Final drive
                  4.388:1
                  4.388:1
                  4.214:1
                  Rear Final drive
                  3.909:1
                  3.909:1
                  3.909:1
                  Reverse
                  3.166:1
                  3.166:1
                  3.166:1
                  Front Differential
                  open / manual electronically controlled center differential lock
                  viscous LSD, full time 4WD
                  Rear Differential
                  open
                  Shift mechanism
                  remote, cable actuation
                  Clutch Cover set load
                  350kgf
                  (3432N)
                  392kgf
                  (3846N)
                  560kgf
                  (5494N)
                  1991 stiva.
                  • sorry bro, somebody cut the axel off in it, that transmission is no good.. I feel sorry you spent all that money on it tho, so I'll give you 20 bucks for it, it will make nice yard art! lmk
                    2008 Kia Rio- new beater
                    1993 Festiva- Fiona, DD
                    1997 Aspire- Babyspire, DD
                    1994 Aspire - Project Kiazord
                    1994 Aspire- Crustyspire, RIP
                    • Yup, total junk, remove it and the HID projector headlight conversion
                      and one of us will be by for the recycling..
                      • I'll give ya 50 cuz I fell worse than zoom zoom
                        I believe the 89 GTX sedan was a BG overseas, which would mean an 88 build date.
                        BPT's only came in FAMILIA GTX and GTR's. There was never a BPT 323 GTX or GTR from the factory ever...
                        Facebook Me!
                        • hahahahahahaha .....i think ill just keep it and go out everyday and just cry since ive put so much into it and its a total loss lol....
                          1991 stiva.
                          • I got my tail mount plate cut and milled today so I should be able to do that up tonight. If it works out I could send you some drawings if you are interested.
                            Facebook Me!
                              Definitely ..help is something I'm not used to lol
                              1991 stiva.
                              • pm me your email address. I'll send you a pdf that is 1:1 scale so you can print it on a normal 8.5" x 11" paper to have a paper templet. It has dimensions too.
                                Its too big to attach here.
                                Facebook Me!
