Originally posted by Nerd Racing
Daniel's TruckStiva Build Thread (56k warning)
I'm curious what ya'll are doing to mod the axles, I'm assuming you mean somehow shorten them to the width of the festiva? Because the protege G axles are too wide. I'd love to be able to somehow mod a pass side escort/protege axle to work in a festiva, so I can use the escort halfshaft with the BP instead of having to mod up the Capri shaft to it.Originally posted by daniel_cogar View Postgot the final axle last week and modified it and the drive train is complete....went to the jy today and got a set of shift cables from a Hyundai elantra, snagged the shifter as well and modified the ends a little bit and it shifts now through all gears and is very tight, the elantra shifter seems shorter, so I now have a short shifter lol.No festiva for me ATM...
What is 52 lb/min? Isn't that like almost 400 HP?2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
1 lb/min = approx. 10hp on a theoretical perfect dayOriginally posted by zoom zoom View PostWhat is 52 lb/min? Isn't that like almost 400 HP?
True but I look at it as flywheel HP, so after drivetrain loss etc it'd work out closer to 7hp per 1lb/min
edit, it was $50.Originally posted by Nerd Racing View PostI paid $60 for mine and it's in better shape
Thing only had 60k on it and was pulled from a bus that had a cracked manifold. The new manifold came with a new turbo.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
Hatch my friend, I'm just making my wheel base wider to accommodate
Facebook Me!
That's a lot of power for a used 1.82008 Kia Rio- new beater
Originally posted by htchbck View PostSeems like the easiest way to go. But Daniel said he kidded the axle, I wanna know what that's all about!
if you use original (not rebuilt) axles from a bg protege or gtx you can take the outer stub off and flip the tripod and put a g series type stub shaft back on the end and your done, the trick here is that you have to use the factory axles not rebuilt from a bg protege or gtx. Believe me there not easy at all to come by. I looked forever for the 3 pieces and have a decent amount of money into them alone.1991 stiva.
