Trimmed out most of the un-used stock harness so i have a nice clean looking engine bay when the swap is completed
All the cut wiring
Then i got the 5 speed tranny bolted to the KJ starting with the clutch..... like my clutch alignment tool? haha
Then the tranny on the KJ
Next time i make it out to the garage i'll be starting to strip the KJ harness and getting it prepped for the install, and i'm also hoping to get the KJ in the engine bay for it's first test fit
So today i trimmed the transmission to clear the coolant lines,
-labelled the rest of the KJ harnes and removed it from the engine
-cut out the KL Y-pipe
And got the KJ into the protege for its first test fit
And here's my hood clearance.... may need to trim the hood bracing a bit
Looking at home! I can see why you're doing that on the Protege 5 and not the Festiva, not that you couldn't make it work one way or another, but that sure takes up a lot more space than the KL.
Yes for sure, this thing is definately beefier then the KL :lol: i thing swapping a KJ into a festiva would be a LOT harder then just a KL swap, but it can still be done
^^You mean the hood scoops themselves? they were basically integrated into the milly hood, so i left them lol
Ugh, i hate wiring..... found out that the TPS and few other sensor wires go into a section of harness i did not keep from the millenia, then to the ECU, so i gotta track down a pin-out diagram so i can get the wiring finished...... Did i say i hate wiring? lol
But on a good note, i've found where i need to supply injector power and power to the sensors, so its progress at least
