I did some looking and only found info on the ecu being atx. How do u trick it into thinking its working, since it seems like it is computer controlled.
My 2002 Protege 5, KLZE to KJ swap
As far as I know there is 2 ECU's in the millenia, one for the engine and one for the transmission
Since all millenia's were auto, the engine ECU I have could be confused somehow causing my issue, that's what I've been trying to look into so I can try to trick the ECU to fix it, but so far no luck
My thoughts are worst case scenario, I'll set up my megasquirt to be plug and play with my protege AND festiva and I'll have a tune for each car depending on which one I'm driving... at least to get me by until I can buy a second megasquirt lol
Dam-man
had to do it. Hey order me up an extra megasquirt, ballin'. That's the only ecu that engine will run on? There isn't a similar model with that engine. Figures all the cool stuff Is always hard to find.
1989 Ford Mustang GT 5.slow
1996 Ford F-150
Unfortunately there's no other ECU options for it
I forgot to update this, on Saturday I got a spare ECU and diagnostic port for it, swapped ECU's and no change, which I expected..... The spare ECU is for just in case I run a megasquirt on it then I have the ECU connector to harvest to make it plug and play
Once I get the diagnostics port wired up I "should" be able to figure out the issueLast edited by Damkid; 11-29-2011, 11:43 AM.
This just hit me tonight.... what if i am missing the factory ignitors for the coil on plugs? could that cause my issue or without them, would there be no spark at all?
I believe you would have no spark at all.1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
^ correct.Trees aren't kind to me...
Ok, scratch that idea lol
Do you think they powerd different sensors from different points in efforts to control voltage/signal to and from certain sensors separate from others?Originally posted by Damkid View PostSo i got my pin-out diagram and i've been digging through the harness a bit more, and i think i'll end up cutting the harness all apart and re-wiring everything myself
It seems that the sensors/selenoids get power from multiple points in the harness and tracking them all down with be a real PITA with the possibility that i'll miss something here or there, so by re-building the harness to how i want it, i won't miss anything
Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
I never did post what i ended up finding but the sensors/selonoids didn't have as many power points as i originally thought.... but you do have a good idea and you could be right
At this point, i think my two options are to either get another Millenia for additional harnesses, OR ran a standalone on it....... i'm leaning towards throwing a megasquirt on it, but lately i haven't had the time to touch the Protege since i'm also in the middle of parting out my Jeep
Here is a quote from the new/previous owner of the P5 that was posted in my build thread on cp.com
Originally posted by DuRWooDWelp, finally got a bit of time off to look at things, she runs nicely now. Rigged up an old EGR boost sensor in place of the map sensor, that did the trick. Soldering wires and tying up loose ends tomorrow afternoon. Vid to follow.
I knew I could fix it if I put the time into it, which I was willing to do it, just never did lol
