Quest for More Power and More Traction! BP+T + AWD Build Thread
  • wow man... great read! looks like you'll have this thing running in no time! I wonder which one your gonna drive the most lol...
    2008 Kia Rio- new beater
    1993 Festiva- Fiona, DD
    1997 Aspire- Babyspire, DD
    1994 Aspire - Project Kiazord
    1994 Aspire- Crustyspire, RIP
    • I'm driving the festiva as much as I can to keep the miles down on the mazda, for warranty reasons.
      Facebook Me!
      • any updates? now that u have the 2 u cant use the i gotta fix my dd excuse lol.
        • yeah yeah, lol.
          I actually did do some work on it today. I finally got the driver's shaft end out of the differential. Then I replaced the axle seals and installed the IM shaft. I also put the axle driver's axle back together, minus a CV shaft boot clamp. I have to swap over to the GTR intake manifold, add my Drilled and tapped oil pan, and the banjo fittings for the turbo oil line, then I can put the motor back under the hood. I am trying to decide if I want upgrade the clutch or not...
          Facebook Me!
          • Do the clutch while your at it
            • Go away Evan! you own a DSM and a chevy so your username is null and void!
              I probably should swap it out but I am trying to get it done in a hurry and the one in there isn't that old. I have to check on the one I have in a box somewhere and see if it's going to be worth the time to throw in there...
              Facebook Me!
              • As you wish Evan:
                I needed some loctite for the clutch bolts otherwise I'd have it back together as well.
                Teaser pics:
                Also... one for the engine bay thread:
                Facebook Me!
                • haha, I want that intake manifold.. and the exhaust mani lol...that things gonna be sweet, you still using planning on using the garrett or did you manage to find a holset?
                  • it's a Garrett on there right now but I'm working on a Holset for when I build the BP.
                    I may or may not be using the manifold, depending on if I can get an EWG added to it easily. Gotta check clearances first.
                    Facebook Me!
                    • any way you could delete the cross brace and feed a pipe up between the manifold and the head between cyl 2&3? lol, it would look sick tho.. I couldn't use that anyway without redoing the gather pipe and fitting a T25 flange on it..
                      • hell no! if you don't brace these manifolds they will crack like Mel Gibson on a Tuesday!
                        Facebook Me!
                        • MOAR UPDATES!
                          Clutch kit is in and the engine and trans back together:
                          Had to swap out the auto BP pan for the 5 speed one I had drilled and tapped for the turbo drain back:
                          old one was a little dirty inside:
                          Bonus! Have an engine with the main bearing support plate in it already
                          And a hint of what I hope to do over the weekend:
                          Facebook Me!
                          • ^ haha, then put the brace(s) back on after you send the pipe up thru there, around it..
                            Where should I drill and tap my auto pan? is there a good spot for it? I've got the drill bit and tap for it.
                            • Originally posted by zoom zoom View Post
                              there is a place for it where the bpt is tapped its in the same spot as he has pictured
                              1991 stiva.
                                you should drill and tap it in the manual pan.
                                Auto pan does not have a boss on it for an oil drain back.
                                you could probably make due anywhere but it will be thin. make it as high as possible closer to the trans.
                                Facebook Me!
