Whats your team name?
$460 festiva to run in Lemons
Current cars:
"We are not really from Iran"rusEfi - DIY ECU
93 EFI: tach cluster, aspire mirrors & spindles. ZX2 master cylinder, BP+G25 swap with a door hinge, rio struts. 205/50r15, 140mph speedometer,rear disk brakes, mini cooper + subaru front brakes rear sway bar
Some recent fabrication:
rusEfi - DIY ECU
that's escort radiator
trying to avoid this:
rusEfi - DIY ECU
Much better with g25mr! This time this was real racing!
Still, we had 4.5 hours of repairs - cooked rear wheel bearing to the extent of damaging the drum & had a boll joint popping out of the spindle twice, probably the spindle is worn out, will probably switch to rio spindles.
Now it's time to revisit rear disk brakes and figure out a way to use 294mm front rotor.rusEfi - DIY ECU
He was totally into racing but had a schedule conflict I believeOriginally posted by Hot_Wheels View PostDid Jason make it out there?
rusEfi - DIY ECU
Do you have these small axles-spindles for the rear? the ones to which the drum is located?Originally posted by Hot_Wheels View Postwell im free this weekend if you need parts.
The drum & bearings we were able to get a NAPA, fix the thing and get it back on the track for the Sunday sessionrusEfi - DIY ECU
our race video:
http://www.youtube.com/watch?v=jUinjwPV-JUrusEfi - DIY ECU
Yep, just 16ga or 22ga sheet metal welded on. We are very down to earth - these fenders are kinda functional on the rear, they are protecting the wheels which are sticking out.Originally posted by Flw Sock View PostHow did you get those fender flares on? Is that just sheet metal welded on? I'm pretty interested.rusEfi - DIY ECU
Wagner BD180027 Brake Rotor has arrived from amazon (it's a weird world now, shopping for parts on amazon) and I could not resist the temptation to see if I have a chance...
... first the caliper did not fit inside the 15" wheel, but I've realized I have these spacers I use on the rear... And with 20mm of spacers seems like it fits:
the dual-piston caliper is either legacy wagon or millenia s, not sure which one.
Would not have time to work on this till July, but maybe I will convince a talented fabricator to at least weld a bracket to the spindle.rusEfi - DIY ECU
