My last engine swap build thread, FANTASTIVA
  • Damkid
    replied
    I remember when I did my BP swap I had plenty of room for the alt..... My guess is that it's just how you have it mounted, have you thought about modifying your mounts to tilt the engine more forward to give more alt clearance?
  • freshtiva
    replied
    Originally posted by Damkid View Post
    ^^or just get a smaller belt so it clears the frame rail
    Thats part of plan B. Somehow Ive got to get the belt on the pulley before I mount the alt. No room to slip it on after its mounted. Crazy !
  • Damkid
    replied
  • freshtiva
    replied
    Originally posted by zoom zoom View Post
    What happens to the top mount for the alt with your motor mount spaced away from the block? Will you just end up with a bigger belt?
    If you go too far back with a bigger belt the alt pulley will hit the frame rail. The distance between the frame get smaller as you get closer to the fire wall, at least on the festiva.
    Originally posted by Christ View Post
    Tried possibly relocating the alt to the front of the car? I believe there's either a PS or AC bracket that naturally belongs there, wouldn't be too hard to bend a steel bracket or two to bolt on for the lower alt bolt, then move the upper bracket and line it up to another open boss.
    I thought about that but it would require some wire harness changes.
  • Christ
    replied
    Originally posted by freshtiva View Post
    The Escort alt just barely hit the spaced out top mount. I tried the festiva alt, its missing a bulge found on the escort alt., I think it will work. My other problem is that I cant get the lower alt bolt in because of my mid shaft bracket. Im going to have to come from right to left under the fender to get a bolt in. Of course the festiva alt is threaded on the right so Ill have to bore out the threads and just use a long bolt and nut to secure the bottom of the alt.
  • freshtiva
    replied
    It definately helps to walk away sometimes, I wish I could spend enough time with my car to get that mad at it lol.. Instead I have days to look at it and think before I can touch it. :\
    Originally posted by MONSOON View Post
    This build is looking great Fresh! Cant wait to see the finished product so I use the info for building mine.
    Thanks buddy !!! Where you been ???
  • MONSOON
    replied
  • zoom zoom
    replied
  • freshtiva
    replied
    That car is looking good fresh, what's next to do on your list?!
    I couldnt get the alt. to mount up the other day, I had to walk away from it for awhile. There seems to be a snag at every turn. I did go to town and found a 5" X 3/8" bolt I was needing for alt. plan B . I might try something this weekend. Ill have to loosen the motor mounts to install a different belt. Ive only got about a 1/4"-3/8" between the crank bolt and the frame rail.
  • zoom zoom
    replied
  • Christ
    replied
    Haha.... it happens to all of us at some point.
  • BigElCat
    replied
    Oops...I got my TV shows mix't up...Loneranger and Kungfu. I'll just shut up for awhile
  • Christ
    replied
    I like how you used a Native American name after talking about the Chinese... lol
  • BigElCat
    replied
    Dawn Power Clean, scrub brush, and a trip to the car wash didn't get my firewall that clean!
    Since Festus will never be the Prima Festarossa of the MidWest, I've decided to paint'eem Ford Blue. The company I work for uses Ford Blue as their official color, so we have plenty around. It's a shade lighter, "almost, but not quite Ford Blue" according to the ex-owners.
    OT; but "my" company was just bought by a large AG company from China. They say "nothing is going to change, and that the Chineese folks aren't even going to come look at our facility. How weird! Ha So Kemosobbie
  • DriverOne
    replied
    Looking good, Fresh.
