Originally posted by Damkid
My last engine swap build thread, FANTASTIVA
You can weld to cast. I had an old timer tell me to "ping" the metal while it cools and it won't crack. He told me to use a shlag hammer and use the point. Hit it as your welding until its cooled. I welded my old turbo setup and it stayed together and it is in TominMo's possesion. I welded nuts onto my bracket where they needed to be. Here's what it looks like. And I think its pretty solid seeing what my car has done. Some people will argue this. This was done with a 15 yr old gas\wire feed 110v welder.-Greg
Redneck Engineer
FOTY - '09
The nuts are big enough for the bolts to pass thru. On the bolt closest to the trans I ground a flat and drilled a hole-Greg
Redneck Engineer
FOTY - '09
I ened up tapping my cast and putting a plate of 3/8 tool steel on the outside with holes to match the block. My bracket wont sit flat on the block it hits the block on the bottom and is about 1" away at the top. Need to make some better spacers for the top bolts.
Originally posted by eurotiva View Post... I welded nuts onto my bracket where they needed to be. Here's what it looks like. And I think its pretty solid seeing what my car has done. Some people will argue this. This was done with a 15 yr old gas\wire feed 110v welder.The Festiva Store
Here is a better pic of my gap. It wont move away from the block without damaging something. I might try my other shaft to see if its different.
Originally posted by eurotiva View PostAnd I think its pretty solid seeing what my car has done.
I cant weld cast..
I wish mine sat flat like yours does. Id think that would be a lot stonger. I wonder if its a cable vs hydro difference.sigpic
wow what a mess, I think I'm about to go thru the same crap, thanks for posting all these ideas guys. I have a capri xr2 axel, with the capri cable G series going on a BP...never registered there was a difference in the eGT/capri axels.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
^ I may be able to remove some material from the back of my midshaft bracket and get it to rotate to be flush with the block. Id be comfortable with that arrangement. I tried my other shaft and its the same as the other.sigpic
Are you using the whole xr2 axel, from the diff to the hubs?2008 Kia Rio- new beater
The differences are in the tranny's, the EGT trans "clocks" the engine differently then the cable Capri trans, which is probably the reason why the int. shaft won't sit flush against the block
Originally posted by freshtiva View PostHere is a better pic of my gap. It wont move away from the block without damaging something. I might try my other shaft to see if its different.
Looks like some welding is gonna be needed. What are your plans with it?
I'd cut the whole end of that bracket off, and have someone weld a piece in between, to "clock" the angle of the bracket to the right angle and fit.
Do you know someone that can do?Dan
Originally posted by freshtiva View PostI ened up tapping my cast and putting a plate of 3/8 tool steel on the outside with holes to match the block. My bracket wont sit flat on the block it hits the block on the bottom and is about 1" away at the top. Need to make some better spacers for the top bolts.
I have key access to our shop. We could bump the 3/8 plate to the proper angle, mill off any extra metal on the original bracket, and get some kinda weld seam between the plate and gussetts on the original bracket.
It's 90 minutes each way to St. Joe. If you had a bare Egt block, that would be helpful. Just some thoughts..I'll pm you my phone #.'88 Festiva L, stock carby engine (with exhaust upgrade), 4 speed tranny. Aspire Struts and Springs, Capri 14" wheels, interior gutted, battery in back
'92 Geo Metro XFi
'87 Suzuki Samurai
'85 F150, modded 300cid
Definitely the difference in a cable vs hydro mounting. Fresh you don't have a cable trans in all those parts?-Greg
Redneck Engineer
FOTY - '09
