Wow. :eeeeeek: Looking good Markus!
My last engine swap build thread, FANTASTIVA
Dan
Awesome motor mount work!
Someday...someway...I'm going to be a Hill Billy.
There is no higher ambition, no substitution :pLast edited by BigElCat; 05-03-2012, 09:59 PM.'88 Festiva L, stock carby engine (with exhaust upgrade), 4 speed tranny. Aspire Struts and Springs, Capri 14" wheels, interior gutted, battery in back
'92 Geo Metro XFi
'87 Suzuki Samurai
'85 F150, modded 300cid
Judging by that level, I'm guessing you are at least .02 degrees off level. Pull it, start from scratch, and do not post another pic until you get it right! It's almost embarrassing to see such shodding work. In fact I'm so disappointed in your craftsmanship, pull everything and I'll be down tomorrow with my truck and we'll get that mess loaded up so you don't embarrass yourself again! Damn near can't take you out in public any more Shadran!ENFORCER - Midwest Festiva Inc., Iowa
#2 .....Cheesehead
#3 '91 White - Donor Car
#4 .....Montana Project
SOLD----Levistiva for $1500
Bought her back for $450
Originally posted by Levitan View PostJudging by that level, I'm guessing you are at least .02 degrees off level. Pull it, start from scratch, and do not post another pic until you get it right! It's almost embarrassing to see such shodding work. In fact I'm so disappointed in your craftsmanship, pull everything and I'll be down tomorrow with my truck and we'll get that mess loaded up so you don't embarrass yourself again! Damn near can't take you out in public any more Shadran!
I knew youd me riding me over this. At least I tried ! What do you expect from a slack jawed weed bender like me ? Thanks for covering this up.sigpic
I guess its about time to take all the junk off of the roof on the car. Its finally sitting on its own four feet again. Sits kind of high. Think I might have to lower it some, looks like the axles are angled downward a lot. I know nothing about lowering a car. If I didnt think Id hex myself Id say Im at least past the half way mark.
Wow..that car is beautiful! Did you get all the wiring figured out or is there still more of that to do?Last edited by zoom zoom; 05-05-2012, 02:32 PM.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
^ Thank you ! Im not sure on the wireing. I have a plan but I dont know if its the right one. Two wires to the ECU, one from the VICS and one from the distributor. Then swap the stock festiva ISC connector out for the one from the EGT. The PRC plug wires directly into the brown existing plug on the festiva. Moving the VAF and battery are optional I guess. Oh yeah, already swapped out the injector harnesses.sigpic
My front tires are like this. \ / What gives ? I was suppose to use festiva LCAs, right ? Ive almost turned the outer tie rods ends all the way in. It appears to be aligned but has a serious toe in.sigpic
what's you camber look like? and is the car on the ground yet?Trees aren't kind to me...
Originally posted by FestYboy View Postwhat's you camber look like? and is the car on the ground yet?sigpic
Here you go
You might have to buy a pair of camber bolts, Fresh. I always have a pair on hand. Replaces one of the strut bolts and allows camber to adjust 1 1/2 degrees. EBay is cheapest but Oreillya carries them. Also, doesn't spinning the tophat 180degrees change camber?
After, thinking about it for a couple seconds, you probably knew all this, so, sorry if it seemed like I was insulting your intelligence.ENFORCER - Midwest Festiva Inc., Iowa
#2 .....Cheesehead
