My last engine swap build thread, FANTASTIVA
  • but if he used a miata manifold or one of rocketman's plenums with the throttle body on the opposite side...
    Facebook Me!
    • Cool...we're thinkin' together instead of swappin' snide comments! I like it.
      IIRC, rocketman hadn't finished his BP plenum, or did he?
      Does the Miata use a BP motor? I don't know these things.
      '92 Geo Metro XFi
      '87 Suzuki Samurai
      '85 F150, modded 300cid
      • it's like the differences between festiva b3's and aspire b3's.. just different parts.
        2008 Kia Rio- new beater
        1993 Festiva- Fiona, DD
        1997 Aspire- Babyspire, DD
        1994 Aspire - Project Kiazord
        1994 Aspire- Crustyspire, RIP
        • well...I got the 4 barrel air horn chopped off, and a flat adapter plate burned out..
          I didn't put the mounting holes in, or attach the adapter to the air cleaner. It's an easy thing to do, but the location of the hardware is hard to judge by pics alone. The air hole is centered, but I ought to make another adapter plate with the hole off center. I'll make another post showing where the hole probably ought to be.
          Burning new ones out is easy, now that I have the auto cad file for the plasma table.
          '92 Geo Metro XFi
          '87 Suzuki Samurai
          • I think the air cleaner could maybe be oriented like this....
            An opening could be made in the sheet metal heat shield (say that fast three times) that goes behind the Festiva grill. This would make Fresh air directly available to the cleaner.
            I looks like a Miata intake manifold would be the ideal solution for having the VAF on the passenger side. I'm not sure, but it may be a bolt on solution.
            There's about 10 for sale on ebay. One of them, that looks like it would fit Fantastiva is mirror polished. $199.00 for that one, but it would look AweSome(!) in this engine compartment. It looks like it would a little over a $100.00 for a non-polished unit.
            I'll try to post a link to the mirror unit. How do I post a link? Any way it's for sale by BTDT Racing-36 199.00 delivered for one that polished on top, etc.
            '92 Geo Metro XFi
            '87 Suzuki Samurai
            • Copy the URL from the browser, then when you type out your message, you can either click the icon in the text box that looks like this: , or surround your link address with the tags [UR L="link address"] and [/URL] without the space.
              The URL to this exact post would be typed out like this:
              [URL=http://www.fordfestiva.com/forums/showpost.php?p=519517&postcount=321] link text here [/URL ]
              Except without a space in the end tag. Done properly, it will appear like this:
              link text here
              And if you click that link, it will show you this exact post, except in a separate window. If you won't want to assign the link a name, just leave no spaces or characters between the brackets from the open and end tags.
              • Thanks christ This would fit Fantastiva, wouldn't it? What year of Egt was the green donor?
                '92 Geo Metro XFi
                '87 Suzuki Samurai
                • Some of the miata intakes won't bolt to a bp, I'm not sure which years it was, but they changed the pattern.
                  • Maybe we should research this, and have Fantastiva all designed out for Marcus when he gets back from vacation.
                    :p
                    '92 Geo Metro XFi
                    '87 Suzuki Samurai
                    • Haha, I'm not the one buying the parts! I am barely qualified to take apart the vics intake I got open yesterday!
                      • lolzzz i feel your pain!!
                        1991 blue L, 5 speed.
                        1988 red L-plus-all stock.
                        • Originally posted by 91mcnasty View Post
                          Man..I bet fresh could put three or four together with the time and money I've spent on this one..
                          • The green donor is a 1993. No vacation, I got sucked into a sequential vortex and ended up here.
                            • Originally posted by zoom zoom View Post
                              98 - 99 was when they changed the pattern
                              This should bolt up, may interfere with the shock tower though. I think the member Biff did a miata BP swap and had to modify his somewhat.
                              Facebook Me!
                              • I think I'll stick with the current intake manifold for now. Maybe a swap after its running if it wouldnt be too much of a mod. BigEl its hard to know the orientation w/o having the filter here. My thinking would be that the widest part of the filter should be down where there is more room. Maybe with the Edelbrock down. That would require an offset hole near the tip of the point on the narrow or opposite end.
