Festicle and xaero
You could use a Miata water neck. Nice work! The rear disk conversion came out awesome. Can't wait to see this thing run.
Yes Rob not sure what to do with that hose it's going to be hot unless we relocate radiator inlet and snake line behind motor?
There is a threw bolt. I wanted to make a dog bone there but was advised that would be an area where the motor could flex and not give much support.
First picture is cable clutch bracket with mustang cable. Pictures of routing dual cables for the disc brakes swap. This is the first festiva with FULLY functional disc brakes with parking brake! We used all escort gt parking cables fit like it was oem! Had to add a hold down bracket in the car. The egt cable fit the handle with out mods.
Originally posted by william View PostNitro is it for the mk1? I was leaning towards 1990 vw cabriolet.
That's what advanced dynamics recommend for my application.Originally posted by shadetree View PostMore info pleaseHere you go guys,the bottom mount is a no brain er. But you have to make a Hat for the top ( Or work with the Black Magic Conical Hats). Don't try running the short shocks until you lower the fronts at least 2" though.Originally posted by Festevil3 View PostCan I have that part number?
KYB 343191 was orig ride quality for 90-95 Corrado
Ext L =25.04,Comp L= 16.65, 8" Stroke
KG9130 was "Increased Performance" strut for
90-95 Corrado curb weight 2,668–2,809 lb
Ext L = 25,Comp L= 17.32, 7.83 stroke
KYB 341007 Excel-G Strut was OEM 83 VW Rabbit @ Amazon $33
This is what I have now and they are working ok with 120 lb Black Magic Springs on my Aspire. Once I lower the front another 3/4" I'll switch over to 170lb in the rear.
Ext L = 21.1 Comp L = 13.39, 7.72 Stroke
Monroe equiv = 71202
KG9105 is what I had and they worked good,but expensive...
Cant find any info that says they were oem on any car??? These are what Charlie recommended.
Seemed like they had slight MORE dampening than KYB 341007.
Ext L = 21.0 Comp L = 13.93 7.12 stroke
Nitro-
ps Dont even waste your time with the Monroe's OMG terrible-Last edited by nitrofarm; 10-02-2014, 07:39 PM.
The Raceland really didn't need much work to fit in the back. A little grinding. It was about the same effort as the kyb agx from a mirage. Might have updates tomorrow.
- Likes 1
