Originally posted by Hot_Wheels
If you use the block vent and the valve cover vent over the alternator, you can block off the valve cover vent that you've got plumbed. That'll help with your hose routing, as that is not a good place for a hose filled with oil/fuel vapor to run. I would mount the catch can on the other side of the engine bay if you can. That turbo will glow red and even with a blanket, that side of the engine bay could see extreme heat. The catch can is full of oil/fuel vapors, which are extremely volatile. Putting a catch can within a foot of a turbine is a recipe for dissaster.
I mentioned on the facebook page, you'll want a decent length of hose with at least 1 bend in it to isolate your heater core, or it will see too much vibration and stress from the engine. The factory puts 2 bends in that hose for this reason. Heater cores do not like vibration or and pulling on the fittings.
It looks like the list is getting smaller and smaller. I'm excited to see what this setup is capable of. Great work!
