Originally posted by nitrofarm
Festicle and xaero
Nitro is it for the mk1? I was leaning towards 1990 vw cabriolet.
That's what advanced dynamics recommend for my application.
I have a good alternative KYB pn If you want it. They are shorter and easily available through eBay for only $ 33.00.
Sent from my USCC-C6721 using Tapatalk
I was gonna run the rear racelands...didn't feel like making the bottom bushing and bolt fit. And the shock body seems way too long, per advancedynamix setup.
Cool.. Let us know when the bugs are sorted.Originally posted by Hot_Wheels View Postthanks! the Russian made the plates. I may be able to get a someone to make a couple sets but it probably wont be for a while due to all the funds are going to the festiva right now. Next hurdle is to figure out how to make the parking brake cable work or maybe add a hydraulic ebarke?
Sent from the depths of hell.
thanks! the Russian made the plates. I may be able to get a someone to make a couple sets but it probably wont be for a while due to all the funds are going to the festiva right now. Next hurdle is to figure out how to make the parking brake cable work or maybe add a hydraulic ebarke?Last edited by Hot_Wheels; 05-11-2014, 09:09 PM.
Rear disc brakes FTW.. When can I place my orders for a swap kit?Originally posted by Hot_Wheels View PostI was replacing the bearing and races on the hubs Russian made for me. I was having a problem with the outer race. The #4 bearing set race was to small! I thought maybe they put the wrong bearing in the box. So I went to 2 different Mcauto parts to come and find out that the drum the Russian used to make the hubs is actully from a Kia rio!
This wouldn't work due to I have Aspire spindles! So now i'm waiting for a new set of hubs.
So the next order of business was finding the mounting bolts for the calipers. I took the calipers to Ace Hardware to try and figure out what thread I needed. Well I couldn't get anything to thread in. So after some research I found out its m10 x1.25 thread. So I ran a tap threw the threads and they where nasty!! These are new calipers I got from Rock Auto. Apparently they didn't use a very good tap. So everything is dry fitted for now. Still need to get some brake fittings so I can bend up the line. Does anyone know what size thread the banjo bolt going into the caliper is? Would there be any issue with using a straight fitting as appose to using the banjo bolts? I want to avoid useing flex lines on the calipers due to the are not necessary.
