Festicle and xaero
  • Hot_Wheels
    replied
    Well I'm not sure what the reasoning as to why. But that's where the directions say to mount it. I also would imagine it will hinder flow because it only has a 3/8 opening. But it's still going to accurate it will average out what it sees in the return.
  • bhazard
    replied
    Why does the FF sensor go on the return line?
  • Hot_Wheels
    replied
    Plumbed supply from tank to fuelab pump, plumbed return from flex fuel sensor to tank.
  • Hot_Wheels
    replied
    Small update.
    Pulled the engine for finishing work, powder coating intake,exhaust manifold,downpipe, pull oil pan to add turbo drain. Need to route turbo oil and coolant lines, mount iat sensor to charge pipe.
    We had to re notch the frame in order to clear the balancer.
    We then boxed of the ends of the lower core support which we reinforced with solid 3/4 round bar.
  • Hot_Wheels
    replied
    Pictures of finished exhaust.
  • Hot_Wheels
    replied
    Thanks Charlie and Will. I can hear it growling in my head!
  • Advancedynamix
    replied
    Nice! This is going to be an animal.
  • william
    replied
    Nice progress! Hopefully have my engine swapped this weekend.
  • Hot_Wheels
    replied
    Waste gate installed, pick up tube installed, battery cut off switch hooked up.
  • Hot_Wheels
    replied
  • Hot_Wheels
    replied
    Getting closer! Exhaust and down pipe done. Custom clutch cable for hydro trans concession done, added ultra racing tie bar. It had to be extended on one side due to trans is lower then stock.
  • Advancedynamix
    replied
    I just so happened to pick up another cheap Miata head on Friday. Here is a picture of the water neck I speak of. The thermostat lives in this and there is a water neck like the one on the B6t goes on top of it.
    You'll want to run the coolant bypass pipe from a Miata as well, otherwise you'll have cooling issues on cylinders 3 and 4. THis setup is not optimal (ask any miata tuner) but it'll get the job done.
  • shadetree
    replied
    That would make things easier from that side yea .
  • Advancedynamix
    replied
    The miata water comes out of the front of the engine ( front meaning timing belt side). I don't have a picture, just Google search "miata 1.6 head" and you're bound to find a picture.
  • Hot_Wheels
    replied
    Charlie do you have a picture of the miata water neck? The one that is on there now I believe is off a b3?
