Dr Dan's B6 build
  • Looks good Dan! I feel your pain, I haven't done much either, but I normally don't anyway with my work schedule. Keep at it, I want to hear how awesome it turns out when you do get 'er up and running, I could use some more motivation as well.
    2008 Kia Rio- new beater
    1993 Festiva- Fiona, DD
    1997 Aspire- Babyspire, DD
    1994 Aspire - Project Kiazord
    1994 Aspire- Crustyspire, RIP
    • Originally posted by zoom zoom View Post
      motivation
      What's that?
      Dan
      • Originally posted by drddan View Post
        While I was installing all new hoses, and on my back hooking up the wiring harness, I thought this would make a nice pic
        Looks like a real "Mickey Mouse" job you're doing there... O.o
        :poke:
        • ^ Let me pick myself back up off the floor!
          Good one!
          Dan
          • Looking amazing, Dan. I'll barrage you with B6 questions in a PM eventually.
            • Gorgeous! (Not you Dan, the manifold.)
              • Hit a small snag test fitting the exhaust downpipe today. The B6 pipe, wont fit the B3 exhaust support bracket. Guess i'll have to take it off.
                Fixed!
                Now I think i'll paint the exhaust down pipe. I have quite a bit of the VHT Flameproof 2000* ceramic coating left! :p
                You best be talkin' about my manlfold!
                You can look, but you cant touch.
                Dan
                • Heh Heh Heh... :p
                  ....Matching valve cover bolts!
                  Tried to find some new ones, no luck, so I painted them to match the Black Wrinkle on the valve cover.
                  Dan
                  • You arent going to want to drive that beaut once you get through with it. Probably going to be a garage queen. :p
                    • Ha! :p I cant wait to drive it!!!!!
                      I prolly will be avoiding puddles, dirt roads, and stuff for a while, but that'll wear off pretty quick
                      Dan
                      • Ohh ... Yuuck....!
                        Broke open the Weber carb for rebuilding .... apparently it NEEDS it. lol
                        Yes, that is oil on the screws, inside the carb, and oil soaked gasket.
                        My B3 had oil issues, and was blowing oil all the time. I had issues with keeping it under control, before it died. The day it died, the oil cap came off and blew ALL the oil out the VC.
                        At least it was well lubricated.
                        Dan
                        • Oh ... My ... Gosh ...
                          How will I get this all back together? :eeeeeek:
                          'Course it does help that I have the full assembly diagram in front of me, and I know which jets are which by memory. :p
                          Dan
                          • This carb is an orig 32/36 Weber, and not the newer Holley-Weber, it has been around for a while. The carb's cast body was very dull (read ugly), so while cleaning it, I decided to give it a little poishing too.
                            On the left is the polished main carb body, and on the right is the un-polished top cover.
                            Dan
                            • Wow nice job on the polish! What do you use to do that?
                              That pic of it all broken down looks like a mess, I have a hard enough time with the carb on my weedeater! ...I'm pretty sure its got a blown HG tho and I've been chasing my tail keeping the carb clean :homersimpsonDOH
                                Tool of the trade:
                                Lots of elbow grease! :p
                                My weapons of choice:
                                The maroon colored pads are Metal Polishing Scotch Brite pads. Not the stuff ya buy for your dishes! They have grit embedded in them.
                                I use the popsickle stick with the pads to get in tight places.
                                I hit whatever I want to polish, with the pads first, to remove the dull oxidation, then follow up with the wire brushes. The wire brushes give it the "shine".
                                Dan
