Well, I think I found out what it is. Sometimes it's the simple stuff that will get ya!
First, swapped disty...no change, still missing, So then I pulled wires and installed rotor and cap...no change. Only thing left was coil, swapped coil...no change
So got to messing with the carb, reved it up by hand to where it was missing, then stuck my finger in the carb butterfles and opened them up all the way...and it quit missing!!!! Finally a change! So at least I know its not elec. or an internal issue with the motor. Phewww!
Some tuning and adjusting on the carb should fix it.
I adjusted the choke, and it helped, but I gotta get back inside the carb, and change up some jetting.
