^ Okay. The Festy went to a shop with a "carb guy" today. Hopefully it will be something simple, or at least cheap! :p We will see.
Dr Dan's B6 build
Dan
Good luck! Awaiting a clean bill of health post! They say when they'll get to it?2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
If you decide to come to Madness, you should be able to join a decent sized convoy for support! It is the best way to roll!Contact me for information about Festiva Madness!
Good luck man. Hope it doesn't cost you an arm and a leg!
I hadn't drove my Festy in almost a week and was glad to get in it this morning and it started right up!
Thanks guys! He is to get to it today I think. Awaiting the diagnosis!Dan
Fingers are crossed!In love with a MadScientist!:thumbright:
Got CUJO back from the shop today. It is not getting enough fuel!
I suppose the mechanical fuel pump will have to go!!!!!
The carb guy, Roger, thought the fuel lines were maybe to small, but he did not know about the fuel pump lobe on the the cam. Somewhere in this thread is how I polished the lobe, to use the mech pump. Measuring the "lift" on the B6 lobe, I did loose some travel, as the lobe is smaller the the B3 lobe. If I remember correctly, the B3 lobe had .267 lift, and the B6 has only .218 lift. That is about 1/16 less lift!
I am going to order a Carter P4070, a rotary vane electric pump, and see if it can keep the fuel bowl full, and the float up where it is supposed to be.
Performance carb kits. com stated NOT to use a mech pump with a Weber carb and insisted on an electric pump, specifcally a Carter 4070!
Carter pumps, are among the best fuel pumps out there.
So here we go, another attempt to solve the riddle of "The Missing".
I was actually thinking that might be the problemo, I just wanted confirmation. :pDan
another option is to shorten the pump spacer by a 1/16th... that will push the pump arm closer to the lobe and effectively add pump stroke by changing the fulcrum point.Trees aren't kind to me...
I'll bet that fixes you up finally, Dan.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Yay! Electric fuel pump installed, and working fine!
Had it going for a while, just wanted to make sure it wasnt going to start acting funny! (again! :p)
Drove it on a few test drives, and I did have a setback of my own doing.
My AC unit wasnt bolted up yet, I cable tied it up while I made sure all was well with the swap. I did not notice it was touching the new lower radiator hose, and after a good long test drive the other day, after I got back to the house, I noticed it was leaking anti-freeze! Looked and the AC unit had rubbed a hole in the lower radiator hose!
It musta just got through, cause it hadnt over heated, caught it in time! Whew! :eeeeeek:
Then while I was fixing the hose I noticed my tire was really low. A good size screw in the rear driverside tire. My new tires, mind you. Errrgh!
Fixed that while I was at it, and bolted the AC in place!
On the bright side, my Festy is now road worthy!!!!!!!!!!!
Good news! So you'll make it to fm6 then??!2008 Kia Rio- new beater
Glad to hear yer up and running!
Yes, i'm pretty sure I will be going!Originally posted by zoom zoom View PostGood news! So you'll make it to fm6 then??!
I am trying to put together a caravan, with folks coming through, or close to the St. Louis area. The more, the merrier!Dan
