Looking good, little tip for future reference.. aluminum foil works great for masking off odd shaped things for painting, such as all the parts in the bay you don't want painted.
Dr Dan's B6 build
good tip, never thought of that1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
Originally posted by Festiva_Fred View PostLooking good, little tip for future reference.. aluminum foil works great for masking off odd shaped things for painting, such as all the parts in the bay you don't want painted.
Yes! Used foil many times. As for my bay, a little paint on some wires wont hurt. I have most wires bungee'd up out of the way, the rest...who cares! :p
I made sure not to coat any connectorsDan
Spray bomb the bay black. It matches any color and hides wires-Greg
Redneck Engineer
FOTY - '09
Dan
how much material is available above the rivits on the friction surface?Trees aren't kind to me...
Originally posted by FestYboy View Posthow much material is available above the rivits on the friction surface?Last edited by drddan; 05-23-2012, 09:59 PM.Dan
Its red. Its fast.-Greg
Redneck Engineer
FOTY - '09
Clutch looks good from my house!
Put the stock disc next to the Branof for a pose, then we'll know if it means bizness.'88 Festiva L, stock carby engine (with exhaust upgrade), 4 speed tranny. Aspire Struts and Springs, Capri 14" wheels, interior gutted, battery in back
'92 Geo Metro XFi
'87 Suzuki Samurai
'85 F150, modded 300cid
Originally posted by eurotiva View PostIts red. Its fast.
Good for at least another 5 HP!Last edited by drddan; 05-24-2012, 04:50 PM.Dan
Looks good! Looks meaner than a 4 spring sprung disk. Lol, say that 5 times fast.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
Done painting stuff mostly, started assembling stuff on the engine.
Had a hard time getting the timing cam pulley off. Had to borrow an impact to break the bolt loose, then couldnt find my 14mm impact socket, so made a trip to buy one, and then found my 14mm as soon as I got back home.
Now the timing crank pulley dont wanna come off. Tried 2 pry bars, but felt as if I was about to break it, so I stopped.
I did manage to put the new water pump on.
Oh well, tommorow's another day. (to invent new 4 letter words) :pDan
Okay what am I doing wrong here?
By drddan at 2012-05-25
I cannot get this B6 crank timing pulley off. I have another, so I wasnt too worried about this, but what a pita.
I know this came off the B3 very easily, when I changed seals last year.
This one aint a movin'
Haynes said use 2 pry bars. I did. (see pic)Last edited by drddan; 05-25-2012, 10:28 PM.Dan
Moving on.
Cam and crank seals installed, new water pump installed, and broken timing crank sprocket replaced. After I eat dinner, the timing belt will go on, too.
By drddan at 2012-05-26Dan
