Dr Dan's B6 build
  • #31
    Looking good, little tip for future reference.. aluminum foil works great for masking off odd shaped things for painting, such as all the parts in the bay you don't want painted.
    -93' L BP swap/e-series, coilovers, RIO front swap, redrilled festy drums, Miata 14" 7 spokes.
    -85' Nissan Sentra 5 spd.
    • #32
      good tip, never thought of that
      1991 blue L, 5 speed.
      1988 red L-plus-all stock.
      • #33
        Thanks!
        Yes! Used foil many times. As for my bay, a little paint on some wires wont hurt. I have most wires bungee'd up out of the way, the rest...who cares! :p
        I made sure not to coat any connectors
        Dan
        • #34
          Spray bomb the bay black. It matches any color and hides wires
          -Greg
          Redneck Engineer
          FOTY - '09
          • #35
            Eggxactly!
            I got my Bahnhof Stage 1 clutch today
            Good, bad, or ugly, here it is
            By drddan at 2012-05-23
            Dan
            • #36
              ....and dont forget the most important part!
              The Bahnhof Performance Decal!
              Dan
              • #37
                how much material is available above the rivits on the friction surface?
                • #38
                  .045 on both sides. Hmmm. Is that good or bad?
                  Dan
                  • #39
                    Its red. Its fast.
                    -Greg
                    Redneck Engineer
                    FOTY - '09
                    • #40
                      Clutch looks good from my house!
                      Put the stock disc next to the Branof for a pose, then we'll know if it means bizness.
                      '92 Geo Metro XFi
                      '87 Suzuki Samurai
                      '85 F150, modded 300cid
                      • #41
                        Its red. Its fast.
                        ^ :laughing9:
                        Good for at least another 5 HP!
                        Dan
                        • #42
                          Looks good! Looks meaner than a 4 spring sprung disk. Lol, say that 5 times fast.
                          2008 Kia Rio- new beater
                          1993 Festiva- Fiona, DD
                          1997 Aspire- Babyspire, DD
                          1994 Aspire - Project Kiazord
                          1994 Aspire- Crustyspire, RIP
                          • #43
                            Done painting stuff mostly, started assembling stuff on the engine.
                            Had a hard time getting the timing cam pulley off. Had to borrow an impact to break the bolt loose, then couldnt find my 14mm impact socket, so made a trip to buy one, and then found my 14mm as soon as I got back home.
                            Now the timing crank pulley dont wanna come off. Tried 2 pry bars, but felt as if I was about to break it, so I stopped.
                            I did manage to put the new water pump on.
                            Oh well, tommorow's another day. (to invent new 4 letter words) :p
                            Dan
                            • #44
                              Okay what am I doing wrong here?
                              By drddan at 2012-05-25
                              I cannot get this B6 crank timing pulley off. I have another, so I wasnt too worried about this, but what a pita.
                              I know this came off the B3 very easily, when I changed seals last year.
                              This one aint a movin'
                              Haynes said use 2 pry bars. I did. (see pic)
                              Dan
                              • #45
                                Moving on.
                                Cam and crank seals installed, new water pump installed, and broken timing crank sprocket replaced. After I eat dinner, the timing belt will go on, too.
                                By drddan at 2012-05-26
                                Dan
