Eurotiva's race garage...
  • -Greg
    Redneck Engineer
    FOTY - '09
    • Sent from my SGH-T399N using Tapatalk
      -Greg
      Redneck Engineer
      FOTY - '09
      • Love that first pic! :-)
        • Reat turbo's are so neat. Do you have to drain all of the lines when you do an oil change? I would imagine there's quite a bit of fluid in there.
          • Originally posted by dliverance View Post
            Rear turbo's are so neat. Do you have to drain all of the lines when you do an oil change? I would imagine there's quite a bit of fluid in there.
            Even if the supply and return lines were full, it's probably a quart or less. With regular-ish oil changes, this would be no problem.
            • There's not much in the lines. The turbo timer runs the oil pump 20 seconds after shut off, so it's mostly back in the pan.
              -Greg
              Redneck Engineer
              FOTY - '09
              • Rolling out turbo cars all the time...
                -Greg
                Redneck Engineer
                FOTY - '09
                • Where's the custom dash pics?
                  1989 Ford Mustang GT 5.slow
                  1996 Ford F-150
                  • Nice to see Greg is still turning wrenches.
                    -M3NTAL MARK! Woo!!
                    • Originally posted by eurotiva View Post
                      Your green in showing!
                      ~Nate
                      Current cars:
                      FOTY 2008 winner!
                      • A couple JZs will do the trick!
