Are you talking about this... (http://www.fordfestiva.com/forums/sh...rossmember+mod) or something differnt?
Powerstiva's BP Swap
Last edited by Powerstiva; 04-07-2013, 09:18 PM.91' Festiva GL Auto EFI--- BP swapped, G-Series swap in the works.
Adjustable VW MK2 front suspension and Aspire disc brakes
Aspire rear axle and drum swapped with adjustable KYB rear suspension
LOOKING FOR RUST FREE SHELL IN CALIFORNIA
Well... Only about 6 months late but I was able to dig up some picture from doing my swap not much since I cant find any of what happened while I was at boot camp but here they are:
Working on disconnecting everything for the pull
Removing the steering column to make it easier to swap the pedal assembly's
Removing the automatic shifter
Not sure what I was doing here!!
After all the electrical had been figured out we labeled it all temporarily with blue painters tape which you can see here, and we were also putting the manual shift linkages in in this picture.Last edited by Powerstiva; 04-07-2013, 09:23 PM.91' Festiva GL Auto EFI--- BP swapped, G-Series swap in the works.
Sizing up the BP before dropping it in!!91' Festiva GL Auto EFI--- BP swapped, G-Series swap in the works.
Nice progress, and good pics keep them comingBarbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
I asked my family to send me some pictures of it in now since its back at home and I'm down in Florida, no promises there though. The next plans for it is a full suspension and brake treatment.
Ive decided to go with the aspire swap instead of the Rio mainly because I had most of my stuff already purchased before I found out enough information to do the Rio swap but from what I can tell its not to hard to go from an aspire swap to a Rio.
Anyways here is a list of the parts I believe that I need, "X" means that I already have it. Please let me know if I don't need anything or if I am missing anything that I will need.
Front Aspire Sway Bar
Aspire Rear Trailing Beam Assembly
X-Aspire outer Tie Rod Ends
X-Control Arm to Sway Bar Bushing
X-Sway Bar to Body Bushing
Shift Bushings (What are these and where can I find them? I just found them on a bushing list somewhere....)
Front Tranny Bushing/Mount
Side Engine Bushing/Mount
Aspire Wheel Bearings
X-KYB Festiva/Aspire Shocks (2 For the rear)
X-1 7/8" x 10' I.D. 150 Lbs Springs (2 For the rear)
VW MK2 Raceland Coilover Kit (Will only be using the front coilovers)
X- 2 1/2" x 10" 250 Lbs Springs (2 For the front, I think these might end up being too stiff)
Small Body Shock Sleve Kit
Aspire E-Brake Cable
Aspire Driver & Passenger Hub/Spindle/Knuckle Assemblys
X- Rio Front Strut Mounts
Festiva Rear Strut Mounts
X- Festiva LCA's
X- Festiva Outter Tie Rod Ends
X- Brake Pads
X- Calipers (Auto Aspire)
X- Rotors (Auto Aspire)
Aspire Brake Drums
Aspire Brake Shoes
Aspire/Rio Stainless Steel Brakelines
Escort GT Brake Booster (Do I actually need this??)
Top Hats???
X- 4x100 Rims (VW Snowflakes)
Tires (Still unsrue of what size to get)
What do you guys all think?
Also how do how do I/Can I change the title of this thread?Last edited by Powerstiva; 04-10-2013, 11:02 PM.91' Festiva GL Auto EFI--- BP swapped, G-Series swap in the works.
BobbySpider's BP is built very similar, and he seems to like itOriginally posted by Christ View PostBarbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
I just got the following the other day:
Small Body Shock Sleeve Kit
4 Federal 185/55 R14 Tires
Teardown should be starting this weekend if all goes as planned. I still need the following parts though:
Aspire Brake Drums
Aspire Brake Shoes
Top Hats???
And I have decided that I will be getting these parts at a later time:
As well as Aspire/Rio Stainless Steel Brakelines unless the ones I have end up needing to be replaced right away.91' Festiva GL Auto EFI--- BP swapped, G-Series swap in the works.
did the calipers come with the aspire knuckles? If they didn't just buy rio calipers and rotors and be done with it, will bolt up just use the rio caliper bolts. Check out advancedynamics suspension thread, you might change your mind about the aspire rear beam but you'll have to get spacers/adapters or dual pattern wheels to swap to 4x100 bolt pattern and have matching rims. He's also covered about everything you need to know about installing coilovers, and links in there to southwest speed where you can pretty much piece together your own coilovers for a decent price if you wanted to do that.
I swapped aspire knuckles with bigger brakes and they seem to do pretty good with the stock master cylinder. You could always upgrade that later if you feel the need. I'm scared to turn 90* corners too fast thinking the rear end is gonna fly up in the air and make me kiss my own ... but I digress.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
zoom zoom,
-I already had the calipers.
-I have thoroughly read through AdvanceDynamics suspension thread multiple times (All 24 pages)and have pm'd him with many questions that Ive had.
-Ive been debating the rear beam for awhile not only because of his thread, but also due to the fact that their hard to find and I was about to decide to not use one but then at the last minute I found one for sale and snagged it up (its shipping right now) but I may decide after driving with it on that I want to revert back to the festy one
-Master Cylinder, for now I decided to use the stock one and possibly upgrade later onLast edited by Powerstiva; 05-21-2013, 06:16 PM.91' Festiva GL Auto EFI--- BP swapped, G-Series swap in the works.
Aspire Wheel Bearings (National's has anyone ever used these before? I forgot to ask for Timken's when I ordered :bull_head
Aspire Rear Trailing Beam Assembly (Including E-Brake Cable, may need new drums and shoes though)
An Extra Aspire E-Brake Cable
An Extra Clutch (Just in Case...)
Custom TopHats
Following parts are still needed:
Festiva Rear Strut Mounts91' Festiva GL Auto EFI--- BP swapped, G-Series swap in the works.
Some Pictures of the parts that Ive accumulated over the last 4 months or so:
Festiva Badge (2)
Brand New Federal 185/55 R14 Tires
Small Body Shock Sleeves
Aspire Knuckles
New Boss Amp for my 2 New subs
Extra Festy E-Brake cable (If interested in it contact me)
Moog Bushings
Weaver Rotors
(2) Brand New Kenwood Kfc-w3013ps 12" 4 Ohm 2400 Watt Peak / 800 Watt RMS Subs
Protege Center ConsoleLast edited by Powerstiva; 05-22-2013, 08:35 PM.91' Festiva GL Auto EFI--- BP swapped, G-Series swap in the works.
Hmmm my ebrake isn't working, but I haven't investigated it much. I have to lift it up to the extreme max for it to even barely work on level ground. If it's got any sort of slope...there is no point in even using it.
Power... just use one sub. 1 12" is more than enough for a cabin the size of a festy. i also recomend a sealed enclosure unless the unit is specificaly designed for a ported enclosure.
take the amp and bridge it mono. it's easier on the amp and the THD will drop, making the sub much cleaner sounding.Trees aren't kind to me...
