Wouldnt mind getting some more details about this swap. Its kind of the direction I was leaning. Since its doesnt make more power than the stock tranny can handle. :thumbleft:
B8-me swap in the works!
- Unknown
- Quentin Crisp
- Bumper Sticker
The swap was really straight forward. I pulled the motor and the trans together out the top. Swapped the engine harness to the b3 harness, relocated the temp plug on the b3 harness(took 2 minutes, no splicing). grinded an area on the back where the axle contacts the oilpan(very easy). Swapped out the b8 motor mount for the b3 mount. Dropped the motor and trans back in. Kept the b8 alternator, pulley, thermostat, coolant pipes. You'll need to swap the temp plugs on the front of the block, and thermostat housing. You'll need to drill a new hole for the motor mount, right next to the oem hole.'93 BP-T 57trim TO4E - Coilovers - 13x7 steelies - 175/60 - 48k mi
How bout the ECU?Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
Yeah its about an inch longer than the b3. Plenty of room for turbo stuff, and I will be utilizing that extra room pretty soon lol.Originally posted by Movin View PostThat is one sweet write up!! And back to DD in two days..? Is there room for boost
in all that? It looks longer than the V6!
I swapped the ecu from the donor car as well as the vaf. Not sure if the vaf was nessecary, but I did it anyway.Originally posted by MONSOON View PostHow bout the ECU?'93 BP-T 57trim TO4E - Coilovers - 13x7 steelies - 175/60 - 48k mi
if it looks diffrent, has a diffrent part number stamped in to it, or is a newer part, just swap it... its eaiser to do when your in the middle of doing all the work... not when everything is all back together and then it wont start or run right...
Mike, AKA the sasquatch
With a cut down 6 inch diesel pipe system!! HUH speak up!!Originally posted by Advancedynamix View PostI vote side exit! :p
That would be the people in the restaurant you just passed
trying to talk!!
2 inch should be the easiest size to work with..Reflex paint by Langeman...Lifted...Tow Rig
The festiva's first start idle with an open header...LOUD!
Thats actually exactly the setup I've had for years lol. But now my car is too low for that to work.Originally posted by Nalleywhacker View PostVery nice you will love it. I love my b8, and I second the side exit. I have a cat into a cherry bomb then a side exit right before the pass rear wheel. It's pretty quiet while cruising not annoying at all and sounds great!
Looks like a new clutch is in order....
Me driving to the muffler shop, feathering the gas making the clutch slip...still open header. :eeeeeek:
