Wait a sec, how are the pictures big again, i re sized them all.. GAHHHHHyelp.
Project: Because I'm Different :D ZMDE/B6 hybrid engine build. From scratch.
Well i just bought a whole boatload of parts:
Machined/overbore crank - $200
silicone couplers - $120
Skyrine FMIC - $free
forged Hbeam rods - $200
tow hooks - $50 (cause it will break down and need towing.
RC 650cc Fuel injectors -$150
Duel feed mtuned fuel rail -$100
Stuff i have already for the bulid:
ARP rod bolts
ARP head bolts
ARP Main bolts
Cometic Head Gasket
Adj Cam gears
Gates Racing Timing Belt
New Water-pump
OMP deep dish wheel w/hub adapter
aluminum flywheel
Things to buy:
-megasquirt PNP (i have a DIYautotune mspnp i want to use but not sure i can)
-Proper Turbo/manifold/wastegate/downpipe or use internally gated t25 and greddy manifold.
-aluminum rad
-Clutch.
Parts I Should buy:
Harmonic Balancer
mfactory diff.
this is what i said at first it would be a budget build. Then after i had 900 into the rebuilt short block (not including forged parts,arp bolts) i decided to go all. I figured with all the machining, head work and balancing it would be a waste to do anything less. I have about 10k with labor and parts and i probably have another 2k with small odds and ends (hoses,gauges, fittings,gaskets). I was planning on building 2 festivas but at this point i may have to become a realist and only build one.
Wow!!!! that is nuts!!!Originally posted by Hot_Wheels View Postthis is what i said at first it would be a budget build. Then after i had 900 into the rebuilt short block (not including forged parts,arp bolts) i decided to go all. I figured with all the machining, head work and balancing it would be a waste to do anything less. I have about 10k with labor and parts and i probably have another 2k with small odds and ends (hoses,gauges, fittings,gaskets). I was planning on building 2 festivas but at this point i may have to become a realist and only build one.
i have a turbo miata race car (pictured earlier on in the thread) that could use a bit more financial support, for me its all getting a bit to crazy.
What i ideally need to do is buy a mazdaspeed 6 sometime in April or May.. I still dont have a nice daily driver im rollin around in a 323 gtx with more rust then metal....and then after that spend the rest of my cash on toys. I finish my degree in april, and start working full time in May. I have to be careful until then.
YAYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$
LOOK AT MY TURBROOOO MANIFOLD!!!!!!!!!
needs to be re-sized but you get the general idea.Last edited by festyfreak39; 12-13-2012, 01:03 AM.
WHOOOOOoooo!!!! V-band!!!!
Mike, AKA the sasquatch
lol i know.... its crazy how much "real" vbands sell for.... thats why i didnt go with a vband turbo on my car was cost... i ended up buying a 5 bolt flange and welding a vband to that flange lol...
you can sort of see that in that pic...
i got my turbo used from a local civic forum... some guy not to far away was selling it for $250 and i thought that was a fair price for a good turbo so i picked it up... if you need any flanges, check out weirtech, they got lots of flanges and weld els for cheap
canadian company too
And his turbo oil drain return isnt shabby either.:thumbs_up:Originally posted by festyfreak39 View Post^^BTW you are a exhaust wrap warrior.
that looks so nicely done :|Some people like to read fiction,I prefer to read repair manuals. Weird I know-
thanks guys
