Project: Because I'm Different :D ZMDE/B6 hybrid engine build. From scratch.
    Wait a sec, how are the pictures big again, i re sized them all.. GAHHHHHyelp.
      Well i just bought a whole boatload of parts:
      Machined/overbore crank - $200
      silicone couplers - $120
      Skyrine FMIC - $free
      forged Hbeam rods - $200
      tow hooks - $50 (cause it will break down and need towing.
      RC 650cc Fuel injectors -$150
      Duel feed mtuned fuel rail -$100
      Stuff i have already for the bulid:
      ARP rod bolts
      ARP head bolts
      ARP Main bolts
      Cometic Head Gasket
      Adj Cam gears
      Gates Racing Timing Belt
      New Water-pump
      OMP deep dish wheel w/hub adapter
      aluminum flywheel
      Things to buy:
      -megasquirt PNP (i have a DIYautotune mspnp i want to use but not sure i can)
      -Proper Turbo/manifold/wastegate/downpipe or use internally gated t25 and greddy manifold.
      -aluminum rad
      -Clutch.
      Parts I Should buy:
      Harmonic Balancer
      mfactory diff.
        for the balance check out the supermiata, cant beat the price! there are no other afforable options. I should have pics with fitment soon. I like where this build is going!
          this car is getting expensive. I have to figure out if i just stop here, or just start building with no expense spared (within reason) I need about 3k more to have the ultimate (in my mind) festy. gawsh.
            this is what i said at first it would be a budget build. Then after i had 900 into the rebuilt short block (not including forged parts,arp bolts) i decided to go all. I figured with all the machining, head work and balancing it would be a waste to do anything less. I have about 10k with labor and parts and i probably have another 2k with small odds and ends (hoses,gauges, fittings,gaskets). I was planning on building 2 festivas but at this point i may have to become a realist and only build one.
              Wow!!!! that is nuts!!!
              i have a turbo miata race car (pictured earlier on in the thread) that could use a bit more financial support, for me its all getting a bit to crazy.
              What i ideally need to do is buy a mazdaspeed 6 sometime in April or May.. I still dont have a nice daily driver im rollin around in a 323 gtx with more rust then metal....and then after that spend the rest of my cash on toys. I finish my degree in april, and start working full time in May. I have to be careful until then.
              YAYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$$$$
                LOOK AT MY TURBROOOO MANIFOLD!!!!!!!!!
                needs to be re-sized but you get the general idea.
                  WHOOOOOoooo!!!! V-band!!!!
                  Mike, AKA the sasquatch
                  • #24
                    ^^now i have to be able to afford the vband housing for the turbo HAH!
                    • #25
                      lol i know.... its crazy how much "real" vbands sell for.... thats why i didnt go with a vband turbo on my car was cost... i ended up buying a 5 bolt flange and welding a vband to that flange lol...
                      you can sort of see that in that pic...
                      • #26
                        I might have to sacrifice the ultra rare indy car vband collector and weld a flange onto it and do a similar setup as you, where did you find your t3? what you pick it up for?
                        Ive thought about a newer chinacharger but i just dont trust them.
                        • #27
                          i got my turbo used from a local civic forum... some guy not to far away was selling it for $250 and i thought that was a fair price for a good turbo so i picked it up... if you need any flanges, check out weirtech, they got lots of flanges and weld els for cheap canadian company too
                          • #28
                            ^^BTW you are a exhaust wrap warrior.
                            that looks so nicely done :|
                            • #29
                              And his turbo oil drain return isnt shabby either.:thumbs_up:
                              • #30
                                thanks guys
