My n/a super b3 build
  • Got started on the blueprinting process. Got everything done except the rod caps, the inside micrometer would not go small enough so have to find my uncles telescoping gauges. All the bearing clearances are within spec so looking good... the cylinder bore to piston clearance is @ 3 thousandths, matt said he wanted me to have 2 thousandths so im calling him today to make sure thats ok but my guess is it is fine.
    • Like the roof rack on your Festy and sweet Countryman!
      -Rafe-
      Things I have for sale.
      Random Festiva Parts
      • Nice pics, looks like your making progress. I can't wait to see some video of this this running
        • Sweet.
          • Re: My n/a super b3 build
            Yeah set up the rack because I bought season passes to monarch ski area for me and my son but haven't even used it yet cuz building this motor... Lol I have been using my girlfriends subaru svx that I have been building for her while she drives my jeep... That countryman is my mom's.. My dad is a mini guy now, he has the 2006 Cooper s John works or something like that. And he bought my mom the countryman brand new 2012. I don't have a garage right now so have to use my parents
            Sent from my LG-LS970 using Tapatalk 2
            • looking good
              Mike, AKA the sasquatch
              • The SVX is an odd looking car. Have always been kind of interested in them. Those weird tiny side windows!
                -Rafe-
                  Yeah I like it though... It was actually designed by the same guy who did some lamborghini designs and did the delorean. Also svx was the first car to go into production exactly the same as the concept vehicle, which is kinda cool
                  • Originally posted by drumnerd33 View Post
                    Giorgetto Giugiaro is one of my heroes. He was an AMAZING designer. He was actually named designer of the century. The SVX is like they said on American Top Gear "The car of tomorrow, that was made 20 years ago..."
                    Http://www.Youtube.com/TheresGabe
                    1991 Festiva L Red: Daily Driver
                    1990 Festiva L White: R.I.P.
                    1988 Festiva L Silver: R.I.P.
                    1991 Festiva L Red B6T: R.I.P.
                    1989 Festiva L White: R.I.P.
                    1995 Aspire 2-door White: R.I.P.
                    1995 Aspire 4-door Red: R.I.P.
                      Yes it is. It's actually a really cool car, I bought it with a blown front diff and didn't want to pay the money for the same tranny so found out that the legacy and outback tranny are exactly the same except the gear ratios were different, svx has 3.57 and legacy and outback had either 4.11 or 4. 44 so I went with the 4.11 then had to use outback rear end 4.11 and swap the ring onto my center section because svx has a vc limited slip. Then spin the gears and make sure pattern is correct. Turned out good has good torque now.
                      • Got a decent amount done today... done with blueprinting other then the valve to piston clearance. Today i started with the ring end gap.
                        checking ring end gap
                        Filing ring to open up gap
                        cleaned up and ready to begin assembly
                        Rings installed
                        bearings in
                        crank installed
                        Torqued
                        Now need to check crank end play
                        .006 looking good
                        Lubed and ready
                        • Looking good man!
                          • NNNnnice!
                            -Zack
                            • hurry up... i need to hear awesome b3 POWER!!!
                              • What is that you smeared on the cylinder walls? Lubriplate 105? Never seen that done before.
                                What clearance did you end up with on the mains and rods?
