Ernie is a blue '93-L 5 speed, with dealer A/C and just over 205K on the odometer. No rust, a few dings on the sides, and a dimply roof. She's been a very reliable ride since I bought it a year ago. Now that it's tax season, I figured it was time to pay her back.
The rear e-brake has no effect while the car is in motion and is minimal insurance while parked on a hill; it holds, but I don't trust it. And just recently I started hearing some noise from the front end. A couple weeks ago I put the car on jacks to do a brake check and find where the noise was coming from and I wasn't happy with what I found. The rotors have seen better days, the guides on the driver's side must be seized because almost all of the wear was on the inner pad, and the noise is coming from the CV's on both axles.
I'm riding on the spare tire too, the one its replacing has a slow-leaking plug and a slipped belt. I got quoted 75 bucks for a new tire, but the idea of one new tire isn't appealing and $150 for a pair is just painful. So I looked on craigslist for a few days, no tires, but I did find an aspire swap. I picked up the pieces for the swap, and the guy also had power mirrors and a white tach cluster. Ernie's steppin' it up, and it only cost $230 (3 wheels, no tires).
Turns out the switch to the mirrors is about 20 years old; plastic gets brittle over a couple of decades, it will need replacing. Also, the power mirrors use fine thread screws in their metal housing... I'll have to find a source for those. And the passenger mirror isn't very sturdy in its housing, I can get some wobble from the glass if I wiggle the whole thing. The driver's side works as far as I could tell, but I could only finagle inward for a moment and then all the way down from the switch when I played with it.
I installed the dash and greased the speedometer cable. Awesome! But it is distracting having these new functions in front of my face. It is so much brighter at night my face hurts from grinning so much! I wish I could add the 20k miles to my new odometer, but I'm not going to spend the time with a drill.
So, in my hunt for wheels (I only have 3) and tires, I found some new National Band 185/70-R13's mounted on Accord steelies for $85. They started looking bigger as I drove home. I even pulled over to size them up next to the car. They're about 2 inches bigger in diameter and width, I'll probably need some spacers but I think they'll fit. I hope they'll fit. When I got home I discovered that my CV axles arrived from O'Reilly. Man are they purdy!
I'm a stay-at-home dad right now and my 14 month-old daughter isn't to be trusted in the garage; progress on the build will be piecemeal, until the weekend comes around. So yesterday during her nap I pulled the car into the garage and put the front end on jack stands. I played with my new tires, but the center bore on the wheels won't fit onto the hub of the Festiva bits. I got the important bits soaked in liquid wrench and got everything broken loose except for the tie rod ends and the ball joints. I've heard that the drive gear in the transmission can drop if both axles are pulled, so I'll save myself a PITA and only disassemble one side at a time.
It appears that someone was a little overzealous when pulling my Aspire parts. I was missing one of the bolts that join the caliper halves as well as both ball joint pinch bolts. Luckily, I discovered that those parts are compatible between the Festiva and the Aspire.
Aaaaand, it's nap time! Gotta get to work!
