my first bp swap began:D
  • my first bp swap began:D
    Im 17yo and began my first bp swap today worked on it 9so hours straight and got motor setting in frame today! !! Started on the no weld mount picked up clutch and oil hopefully see her running in the am would post pics but my "smartphone" wont let me updates tomorrow evening!
    89 festiva all of a mighty 1.3 Tha Black Bullet and good ole casper got casper when I was 15 and loved em ever since
    ...well get on it! this time with pictures!
    1989 Carby L: Stock. Slow.
    1998 Mustang Cobra: ported heads, cams, longtubes, 4.30 gears
    2016 Focus ST: daily driven go-kart
      pix or it doesn't exsist....
        Here's a few pictures of it
        Little b3 vs. bp. https://mail-attachment.googleuserco...29gli5CCF1HAkU
        Bp. https://mail-attachment.googleuserco...ekQxd63bQPryeU
        My first test fit to check clearencen. https://mail.google.com/mail/u/0/s/?...attd&safe=1&zw
        Firewall clearencen for the intake https://mail.google.com/mail/u/0/s/?...attd&safe=1&zw
        Testfit after firewall hole much better. https://mail.google.com/mail/u/0/s/?...attd&safe=1&zw
        My own little idea I took the stock bp pulley the 2 belt style and put it into the lathe and made into single groove instead of having to use little ole v-belt pulley off b3 https://mail.google.com/mail/u/0/s/?...attd&safe=1&zw
        Plan to finish up mount tommorrow and wire in
          Re: my first bp swap began
          You can't link to attachments in your email.....
          91GL BP/F3A with boost
            Maybe this work well hopefully..... Good to go
              Nice job!
              88L - Awaiting bigger and better things
              92L - Dead and needs love - was DD
              91 - Shell with title
              92GL - receiving B8 Swap and will be DD
                Looks like your making progress, keep up the good work!
                  hmmmmmm hmmm i wonder who has the record for fastest bp swap........ besides chris or greg lol :highly_amused: hold up i think chris was b6t swapped, but maybe he helped someone else do one... :dontknow:
                    Well made no progress today due to the weather will tommorrow though!
                      Dude. GreenBullitt and I want the title! 1992 EFI festy to a running BP/G-series.
                        Took couple days do to weather installed new pulley started wiring finished the injector harness and all the other plugs besides the 2 that run to the ecu now would it be easier if I removed the dash to do this?
                          If you can get a set of ratchet wrenches from Autozone for about 25.00 or so, you can unbolt the fuse panel and get to the bolts. It took me about 30 minutes of actual work time to swap the ECU in mine. It's a 10mm bolt. One is easy to get, the other one is the reason for the ratchet wrenches.
                          Oops, I thought you were talking about changing the ecu. You can hook up the 2 wires without pulling the dash.
                          Jerry
                          Team Lightning
                          Owner of Team Lightning
                          93 L Lightning. BP
                            Thanks for that lol I found out the ecu in the escort is an aftermarket one and intend on using it instead of the stocker
                              Go man!
