Very impressive, can't wait to see it completed.
Ian's B6T Festiva build
VERY nice.Any difference that makes no difference is no difference.
A couple of minor updates...
My first attempt at modifying the rear bumper beam didn't work out. Here's the second attempt....
Also got the rear wiper reservoir in, the hose fed up the C-pillar and the nozzle installed.
Next up: remove the gas tank and the rear axle beam. The new tank and fuel pump I put in the red car will be switched over to this car as will the entire Aspire rear and front brakes.Last edited by fastivaca; 07-26-2015, 06:32 PM.Ian
Did you just reinforce it?Any difference that makes no difference is no difference.
I cut off most of the material leaving the back plate. Welded on two pieces of 1/8" x 2" x 48" to reinforce what was left. Also had to trim the ends a bit and cut 1/2" or so off the top. Here's a shot from one end...Originally posted by sketchman View PostDid you just reinforce it?
The ATH bumper now slides into place nicely and mounts to the four lugs below the hatch opening (had to drill holes for them of course) and the stock spot in the wheel arch.Ian
Ahh OK. Awesome. I just pulled the foam, but that's much nicer and slimmer.
Nice job.
Last edited by sketchman; 07-26-2015, 07:11 PM.Any difference that makes no difference is no difference.
Gas tank safely removed....
Ian
New license plates arrived today!!!!
Ian
I wish I could get those plates for my festiva..... Buuutttt that was taken by the previous owner of my festiva.... Ugh lol
Is there any process by which you could buy the plates from Fred? That is assuming he'd be willing to sell them of course. 😊Ian
I asked about it once and the plates can't be transferred between people
So I was gunna go "V6TIVA" lol
The car spent a lot of its life in BC which probably is a biggest factor in its condition.
I got the sound deadener from www.b-quiet.com in Lethbridge. Makes a big difference, especially on long trips. The best way I can explain it is that it takes away the buzziness. Doors feel more solid too and the stereo sounds much better.Ian
