Went out today and bought a vacuum gauge kit from harbor freight.
Got the idea from tominmo.
After following his tuning experiments.
Probably got the same kit he did it was $15.
Went outside and let my car warm up for a while.
It was cold outside so it didn't heat up above 165* parked and idling.
But adjusted the ignition timing+fuel pressure+idle.
Might have to readjust on a the next hot day just to make sure its not overadvanced due to colder weather tuning.
We live at 1200ft above sea level so the max vacuum possible is reduced by around 1.2"hg.
I started at the stock ignition position from the mark on the distributor before I started messing with everything.
And turned the fuel pressure down to stock pressure 38lbs.
Readjusted the idle and started from there.
And made sure I had the jumper in place.
After fiddling around with everything.
Bumping the fuel pressure up to 40lbs brought the vacuum up to 20".
Then adjusting the ignition timing steadied the needle reading.
Full advance on the distributor brought it to 21+
But I to thought that was too advanced so brought it back down a couple degrees.
It's not advanced much above stock timing just a smidgeon.
Maybe 1-3*
I run premium gas always so I'm not worried.
And finally adjusting the idle back to stock range got it sitting at 20" steady.
Which at sea level would be slightly above 21"hg.
Went for a drive and everything is smooth and better adjusted than I could ever get it by hear and feel.
No pinging.
Smooth idle.
No hesitations while accellerating.
No bogging.
Low end torque is also there as well.
Everyday you learn something new.
And hone in on your skills/techniques.
Maybe 1-3*
No pinging.
Smooth idle.
No bogging.
