Okay haven't had any luck finding a bell housing but been doing some other number work and lots of reading.. Okay so my lift is at 7" right now in the very last pic I posted that would be 12" lift with it jacked up and almost all the angles are perfect the cv angles little steep at 35 dagrees but only 3 dagrees more then they are now sitting on the ground, stearing rack I'll need dropped and a sway bar link thang made, if I go this route I'll get rid of the blocks compleaty (will make a lot of you guys happier) and go to I think 20" long springs 10" of travel with aspire break swap. I think it would be just as safe and just a little more expensive to do a 12" suspension lift then a 7" lift
but what do you think just do a 7" suspension lift that I know will bolt on or 12" with just a little more work? Ether way it will be around $1500 to do and a feeling of satisfaction when done; I'm staying with 30" tires ether way just FYI
I still got the stock size tires on the rear so with 30"a on it will sit 5" higher
here we see it looks sexy with a red tranny I need to put the valve cover back on to match
but ether way I go with the tires it looks pretty sick!
I got the valve cover bolts painted black and are on now
and I think the red tranny goes surprisingly well with it all
