:cry_smile:
Matthew
If love to see Matt get turboed-Greg
Redneck Engineer
FOTY - '09
Fixed it for ya.Originally posted by kumalaba View Postme also greg, it should be faster than my old sohc b6 rt(barbie car) which i outran a fiat abarth with & kevin a new 200h.p. turbo beetle!90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
lol
i was hoping someone else would post this, quote, i pulled and yanked on it, and it finally let go. i greased it at home and it is good again. my apologies for posting this:pOriginally posted by drddan View PostDont tell anyone, but I hate seatbelts ...oh I guess its out of the bag now!!! LOL
... And in illinois where it is mandatory to wear them, too!
I am a wild crazy rebel who doesnt where seat belts!
Actually, funny instance, I DID wear them yesterday, at least I tried! I put the belt on and it woudnt go in. I pushed it real hard, it went in, then woudnt come out!!
I was locked in the seatbelt!
When I got to the meet, I had to pull the shoulder belt over my head, then pull the belt out as far as it would go, to get the lap belt over my head, to get out of the car!!! WTH!
I pulled and yanked on it, and it finally let go. I was afraid to lock it up again!
I greased it at home and it is good again.Last edited by kumalaba; 04-01-2014, 02:40 AM.Never Hire a Boy to do a Man's Job!!
Great thread! I've been away for a bit, doing other things. It looks like you guys have been having fun
Hi mikey, long time no hear from. Yep we're still having fun here.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Quick question for you. Do you know or could you check what your ign timing is set to on Matthew? I just got mine running and the cam broken in and my timing seems way advanced but my cam was ground with 4 deg adv. Im just looking for a comparison so I know I don't go insane trying to set the timing.
I'll check it out, but not today. It's raining all day. Should have a chance tmw. I don't know the specs of this turbo cam he put in there, tho.Originally posted by gergorian View PostQuick question for you. Do you know or could you check what your ign timing is set to on Matthew? I just got mine running and the cam broken in and my timing seems way advanced but my cam was ground with 4 deg adv. Im just looking for a comparison so I know I don't go insane trying to set the timing.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I should be able to get to it tmw. But bear in mind that my cam is different from yours, so I'm not sure it would be meaningful data for you. Personally I think you would be better off just starting with 10 degrees BTDC, then adjusting two degrees at a time, to find where it likes to run best. And on premium gas BTW.Originally posted by gergorian View PostOk cool. Yeah, ignition timing between the the cams shouldnt be too far off I think.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
