Originally posted by bhearts
hartstiva
I made a new one for my Nissan and just ended up using pieces of 1x1 for supports underneath, but I didn't think of doing it until after I had already staples the carpet down so I just shot some screws through it."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
Exciting stuff!Originally posted by bhearts View Post
got these pretties in the mail today. Maybe I'll have all the parts together to start the build this weekend.
Sent from my SM-G900V using TapatalkDriving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
My engine bay is a mess. Got the engine pulled and ready to start bay prep. Have a couple surface rust spots that need attention. Im looking at doing it a darker grey color. And I'll have fluorescent accents in certain places. Would anyone advise against media blasting the entire bay before paint. It could really use the tlc
The factory paint makes a good primer if you scuff it up correctly. I wouldn't media blast unless it was dry ice. The mess that sand, glass bead, or shells leave isn't worth the time invested. You'll also risk damaging the seam sealer. These cars are more held together with seam sealer than weld, so damaging that is not a sound idea.
Save yourself the time and effort and just sand and properly treat the rust spots and scuff the rest of the bay. Be sure to degrease the bay a few times with a strong degreaser. A pressure washer helps get the grease and oil from those tight spots.
I prefer ZEP degreaser. It comes in 2 strengths and can be purchased at Walmart or Home Depot. The purple product with the chain and sprocket on the picture is strong enough to strip the paint off your car, so be careful with it. It also dissolves aluminum, so keep it off aluminum parts.Last edited by Advancedynamix; 06-29-2016, 09:23 AM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Thanks Charlie. I knew somebody would advise against itOriginally posted by Advancedynamix View PostThe factory paint makes a good primer if you scuff it up correctly. I wouldn't media blast unless it was dry ice. The mess that sand, glass bead, or shells leave isn't worth the time invested. You'll also risk damaging the seam sealer. These cars are more held together with seam sealer than weld, so damaging that is not a sound idea.
Looking forward to the before and after photos of the engine bay. A nice, clean, we'll painted engine bay makes a huge difference. Take your time and do a good job, you'll appreciate it for a long time.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
I've had quite the struggle getting these wheels to clearance my spring perch. I got a 175 series tire on the back instead of the 205 it came with. Along with a 5mm spacer. Still got 7 full turns on the lug nuts so I think I'm safe. Now to get the front on and put the car on the ground
Is this hole in the casting typical for a 1.6
Here's a little rod compassion for you. These manley rods were stock weight rods, but noticeably beefier. Zeph and I got most of the small block assembled. Still need to do water and oil pump tho.
lug nutz
