Not a bad idea, but I'd really like to do the dash spot. On the middle dash.But they could have to be enclosed, I don't want to see the backing of the gauges
Sent from my SGH-T989 using Tapatalk
made some progress on supporting mods. Here's the list of the glove box cluster : boost pressure at the turbo. Boost pressure at the manifold. Oil pressure. Fuel pressure. Water methanol injection pressure. Oil temp. And a black seventh hole. Any ideas? I don't really consider a volt gauge vital info. And who doesn't want to see their fuel pressure rise in proportion to their fmu. The inovative wideband will go up in the direct line of sight. Because I consider this the most important gauge. Maybe on the steering column. Maybe under the dash bonnet in front of the fuel gauge. That would be nice and hidden.
all the gauges. I was thinking about doing some version of a infrared back light activator. Where I have some infrared leds in that panel that reflect off the inside of the glove box when it's closed and an optocoupler to deactivate the circuit when it's closed. But I think a simple pressure switch might be better. Or just a normal toggle switch. So I can choose when the lights are on or off
But... I don't think I have room on the passenger side engine bay. I know pre turbo vaf isn't ideal because of rich fuel during shifts. The big question. If my tb was right over the transmission, and I couldn't get the throttle cable to connect due to it being too long, could I trim some off to make it the right length.
