new build!
  • Are you gunna be ready?
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    • Put the fronts on today and a alinement.
      The fronts are 12 inch springs preloaded to 11 inch (150# spring)
      Rears are all the way up 10 inch 120 springs.
      -3.5 camber front and - 2.2 camber rear 0 toe in front
      Ride is pretty firm but handles awesome and if there like the rears they should loosen up with some miles.
      • Well it's been a while I've got about 5k on the g series swap it took me to Madness and back .
        I'm not loving to 20 50 bike oil in the cold mornings it's harder the shift then my last trans with gear lube.
        I'll be swapping that out for some atf for the winter then to some lighter oil for autox season.
        I painted it up with so "cast aluminum" by vht .
        And painted to 5th gear cover with rustoleum black..
        New axels from rock auto it was like 130 for both!
        And a excedy clutch kit.
        Hi, I've shared 1 photo via Photobucket. Please click the link to view photos: http://share.photobucket.com/sharepr...hp?id=MjAxODk=
        And my photo bucket just quit working. ... thats all for now .
        I hate this new update to photo bucket I can't find the direct link so my pictures will show up like they used to.
        • Yay for photobucket :p
          Have you considered staying with gear lube for the winter? You can get synthetic gear lube thats about a 5w30 viscosity if you want to go that light. Then at least your staying with gear lube and not switching back and forth with additive packages that may not mix the best.
          • Are you using the pb app? Looking good!
            • Yeah I'm using the photo bucket app.
              I thought of using gear lube but I have a full gallon of merccon lv here for my wife's car that got totaled and I don't have any other use for it lol
