new build!
  • Nicely done. Good approach. This way you can get all the wiring out of the way before the engine goes in. Very good idea. Oh and your other post says something about world's slowest build.... My Festiva is still not done and I started my build somewhere around 06.... Lol. Keep up the good work.
    • Looking good William! Post pictures when you get your ECM mounted. I didn't have A/C in my car, so I had more room. Are you bringing the car to Madness this year?
      • Originally posted by william View Post
        Test fitting my b6d harness threw the passenger fender.
        I may have to lengthen a few wires to get my ecu where I want to mount it with having ac
        Watching this with great interest. Just about to wire my B6T Festiva and I have A/C!
        Ian
        • Man, after looking through this I think I'll paint my rear panels this weekend...if it doesn't rain.
          1993 Festiva - White/Black - 5 speed
          • Originally posted by red90festyonair View Post
            Thanks I'm hoping to get all the wiring in place by Saturday and then swap in the b6d.
              Thank you and no unfortunately I won't make madness this year. I have a wedding to attend that day. I'm hoping to mount my ecu behind the passenger speaker. I'm still trying to figure out what all I can remove from the capri harness. And I may have to lengthen 2 plugs to get them up to were they need to be.
              The charcoal canister valve thing and fpr
              • Dubble post
                • Originally posted by fastivaca View Post
                  I'll keep the pictures coming. It was getting late yesterday so I didn't get many.
                  • Originally posted by SWRT View Post
                    Sorry for all the post but I can get my phone to multi quote
                    I recommend using a 2k clear.
                      Is that stuff as dangerous as people say?
                      I was looking for a satin finish vs gloss. I'll see what I can find.
                      My time to do stuff is sadly very limited and it's been raining a
                      butt ton here lately. I'd love to do some stuff to my car like you
                      do with yours though. The sound deadening would be awesome.
                      Any guess at how much weight it adds?
                      • No Idea on weight the deadner adds. I would say under 3 lbs. For the roof but it's been awhile.
                        And 2 k just means it has a hardner in it. Witch helps with uv protection and durability i would recommend a cheap 3m spray mask if your not outside.
                        Sent from my SAMSUNG-SM-G900A using Tapatalk
                        • Ok I'm take wires out of this harness I don't need do anybody know what the relay next to the fuel pump relay? From the looks of it I don't need it. But would like confirmation.
                          • I was able to remove this from the harness.
                            lengthened 3 wires to get this
                            This gives me much more wire to move my ecu behind my speaker. All other wires were long enough but those 3 I just made the 3 the same as the others. Added about 8 inches.
                            I could have shortened all wired about a foot but I just returned them as factory did.
                            • Wires coming down from fire wall.
                              ecu's new home.
                              This is just temporary so I can fab up a mount. I will dollie out the factory tab there and use some flat stock bent into 90's to secure it. I may end up mounting my fuel pump relay here.
                              • Nice work!
                                Dan
